Setting up routing to Cellular and WAN
nadeesh.sam
Hi everyone!
I'm trying to setup internet access to two VLANS I have on my IR829 router. I want the VLAN10 traffic to go through the Cellular interface and VLAN20 traffic to go through the WAN (GigabitEthernet 0) interface. I've tried setting up NAT and PBR and I still cant get the VLAN20 to access the internet (I can access internet on VLAN10 through Cellular 0)
Any help would be greatly appreciated!
Cheers
I tried debugging the ip policy and this is what I see,
*Apr 6 01:05:07.650: IP: s=172.16.6.3 (Vlan20), d=8.8.8.8 (GigabitEthernet0), len 62, policy routed
*Apr 6 01:05:07.650: IP: Vlan20 to GigabitEthernet0 14.192.221.164
*Apr 6 01:05:07.762: IP: s=172.16.6.3 (Vlan20), d=31.13.70.3, len 60, FIB policy match
*Apr 6 01:05:07.762: IP: s=172.16.6.3 (Vlan20), d=31.13.70.3, len 60, PBR Counted
*Apr 6 01:05:07.762: IP: s=172.16.6.3 (Vlan20), d=31.13.70.3, len 60, policy match
*Apr 6 01:05:07.762: IP: route map PBR_WAN, item 10, permit
*Apr 6 01:05:07.762: IP: s=172.16.6.3 (Vlan20), d=31.13.70.3 (GigabitEthernet0), len 60, policy routed
*Apr 6 01:05:07.762: IP: Vlan20 to GigabitEthernet0 14.192.221.164
*Apr 6 01:05:07.764: IP: s=172.16.6.3 (Vlan20), d=8.8.8.8, len 68, FIB policy match
*Apr 6 01:05:07.764: IP: s=172.16.6.3 (Vlan20), d=8.8.8.8, len 68, PBR Counted
*Apr 6 01:05:07.764: IP: s=172.16.6.3 (Vlan20), d=8.8.8.8, len 68, policy match
*Apr 6 01:05:07.764: IP: route map PBR_WAN, item 10, permit
Here's my current configuration.
IR829#sh run
Building configuration...
Current configuration : 4290 bytes
! Last configuration change at 02:18:48 UTC Wed Apr 6 2022
version 15.8
service password-encryption
service unsupported-transceiver
hostname IR829
boot-start-marker
boot-end-marker
enable secret 5 xxxx
enable password 7 xxxx
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 11 000
no ignition enable
ip dhcp excluded-address 172.16.5.1
ip dhcp pool ENG
network 172.16.5.0 255.255.255.0
default-router 172.16.5.1
dns-server 8.8.8.8
ip cef
ipv6 unicast-routing
ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
chat-script INTERNET "" "ATDT*99#" TIMEOUT 30 CONNECT
license udi pid xxxx
redundancy
controller Cellular 0
lte sim data-profile 1 attach-profile 1 slot 0
lte sim fast-switchover enable
no lte gps enable
lte modem link-recovery disable
interface GigabitEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly in
no ip route-cache
interface GigabitEthernet1
switchport access vlan 10
switchport mode access
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
no mop enabled
interface Wlan-GigabitEthernet0
switchport access vlan 20
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
description -hologram interface-
ip address negotiated
ip nat outside
encapsulation slip
load-interval 60
dialer in-band
dialer idle-timeout 300
dialer string lte
dialer-group 1
ipv6 address autoconfig
async mode interactive
routing dynamic
interface Cellular1
no ip address
encapsulation slip
shutdown
interface wlan-ap0
ip address 1.1.1.1 255.255.255.255
interface Vlan1
no ip address
no ip route-cache
interface Vlan10
ip address 172.16.5.1 255.255.255.0
ip nat inside
interface Vlan20
ip address 172.16.6.2 255.255.255.0
ip nat inside
ip policy route-map PBR_WAN
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
interface Dialer1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT_CELL interface Cellular0 overload
ip nat inside source route-map NAT_WAN interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip access-list extended LIST_CELL
permit ip 172.16.5.0 0.0.0.255 any
ip access-list extended LIST_WAN
permit ip 172.16.6.0 0.0.0.255 any
ip access-list extended LIST_WAN_ALL
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
ipv6 ioam timestamp
route-map NAT_CELL permit 10
match ip address LIST_CELL
match interface Cellular0
route-map PBR_WAN permit 10
match ip address LIST_WAN
set ip next-hop dynamic dhcp
set interface GigabitEthernet0
route-map NAT_WAN permit 10
match interface GigabitEthernet0
control-plane
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
modem InOut
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
rxspeed 150000000
txspeed 50000000
line 4
no activation-character
no exec
transport input all
line 8
no exec
rxspeed 150000000
txspeed 50000000
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
password 7 045802150C2E1D1C5A
login
transport input none
no scheduler max-task-time
no iox hdm-enable
iox client enable interface GigabitEthernet5
no iox recovery-enable
end
good to know that it is working, although I also do not really understand why, as adding a static route with an admin distance of 250 would just mean that this route only gets into the routing table when the primary route is down...
Either way, the warning
%Warning:Use P2P interface for routemap setinterface clause
is just that, a warning. You get a similar warning when you configure a static route with an Ethernet interface as the next hop, rather than an IP address as the next hop. The warning basically just tells you that you are 'wasting' resources because the interface has to arp for the IP address of the other side.
5 Replies 5
Hello
Amend the  PBR statement, test again
or
set interface GigabitEthernet0.
Kind Regards
Paul
judging from your debug output, the PBR seems to actually be working. Try and simplify the NAT as below:
--> ip nat inside source list 1 interface Cellular0 overload
--> ip nat inside source list 2 interface GigabitEthernet0 overload
--> access-list 1 permit 172.16.5.0 0.0.0.255
--> access-list 2 permit 172.16.6.0 0.0.0.255
Hi Georg!
First of all, I got to say I got this far thanks to your other replies here! Cant thank you enough
I got it to work yesterday after setting another ip route,
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp 250
I don't know why it works. It would be great if you could shed some light on it.
Another thing I'm worried about is when I set the following config I get a warning saying
Is this something to worry about? What is the best way to do this?
  set interface gigabitEthernet0
Thanks again!
Nadeesh
nadeesh.sam
Awesome! I'm glad it's working too. Thanks for your help!
