VLAN problem with ROAS
ARPhillips
Hi all,
I'm currently studying for my CCNA and have set up a home lab up till now been using packet tracer. On the sim I have no problem as all setting up a ROAS. Translate it to real life and I can't get it to work. I have a real basic running-config on both switch and router. Nothing can ping anything.
I've followed CBTnuggets videos and checked my configs against the ones in the lab to no avail. On a debug the only thing I saw out the ordinary was the trunk port going down and then back up every time the PC was trying to ping.
I've attached both running configs, any help would be much appreciated.
PS: I did disable the windows firewall as well, just in case
Hi Paul,
Thanks for your reply. Apologies I took so long to respond. My configuration was correct, I had another router arrive today and I plugged in the exact same config and worked straight away.
It would appear I just had a faulty router is all.
21 Replies 21
Hello
Can you explain what ROAS is?
I am assuming the trunk is connected to the router and fa0/2 is connected to you client?
If so your config of the router and switch is okay, it shouldn't negate access, does the client have the correct ip addressing?
Kind Regards
Paul
Hi Paul,
Means Router On A Stick.
So yeah, trunk is 0/1 and client 0/2. Client is configured correctly. I did have a VLSM as I wanted to try those out but bought it to a /24 bit mask in case my maths was wrong but to no avile.
Kind regards,
Ross
Hello
This then should work as it its, no need to change anything, Have you changed the cabling?
sh ip arp
Kind Regards
Paul
Hi Paul
Yeah, tried new cables, I've replaced them all with ones I know to work.
This is the output for sh ip arp on the switch
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.1.1.50               1   c860.00a2.f262  ARPA   Vlan50 <---- initial pc
Internet  10.1.1.100              -   000d.296a.e580  ARPA   Vlan50 <---- Vlan ip for telnet
Internet  10.1.1.200              3   c860.00a2.f262  ARPA   Vlan50 <---- PC I'm using to telnet with
both PC's can ping the IP address for the VLAN, cant get to the router.
and the router
Internet  10.1.50.1               -   000b.5faa.51c0  ARPA   FastEthernet0/0.50
Another odd thing I wasn't expecting, I set up telnet on the switch so I could run both terminal windows. I initially had it in vlan 1 issued the no sh command and it shutdown vlan 50. I have turned it back on now.
king regards,
Ross
As originally configured vlan 50 from the switch would be operating with tagged frames and the router should have correctly processed those tagged frames. If you change one device to treat vlan 50 as the native vlan then both devices must be changed that way. And I do not believe that tagging or not  tagging is the issue. So I suggest leaving it the way that it was originally configured.
The output of show arp is helpful
notice the mismatch between the router address and the switch/PC addresses. If they are both in the same vlan then they should both be in the same subnet.
If you turn on debug arp on the router I suspect that you will see arp requests coming from the PC and an error message on the router about wrong cable. Change the router IP to be in 10.1.1 or change multiple 10.1.1 addresses to be in 10.1.50.
Rick
Rick
Ross
In response to your statement " I initially had it in vlan 1 issued the no sh command and it shutdown vlan 50. I have turned it back on now." Many layer 2 switches are restricted to having only a single active vlan interface. If interface vlan 50 was active and you brought up interface vlan 1 then 50 does get shut down. Be aware that we are talking about operation of the layer 3 vlan interface. It did not shut down the layer 2 vlan 50. vlan 50 continued to operate just fine forwarding layer 2 Ethernet frames. What was impacted was how the switch would process IP packets to or from the switch.
Rick
Rick
Hi Rick,
I can't believe I missed that! I have changed the subint ip address to 10.1.1.1/24 (same subnet across the board) trying to ping 10.1.1.50 from 10.1.1.1 with debug arp gives me;
*Mar  1 00:12:04.995: IP ARP: creating incomplete entry for IP address: 10.1.1.50 interface FastEthernet0/0.50
*Mar  1 00:12:04.995: IP ARP: sent req src 10.1.1.1 000b.5faa.51c0,
                 dst 10.1.1.50 0000.0000.0000 FastEthernet0/0.50.
*Mar  1 00:12:06.995: IP ARP: sent req src 10.1.1.1 000b.5faa.51c0,
*Mar  1 00:12:08.995: IP ARP: sent req src 10.1.1.1 000b.5faa.51c0,
*Mar  1 00:12:10.995: IP ARP: sent req src 10.1.1.1 000b.5faa.51c0,
*Mar  1 00:12:12.995: IP ARP: sent req src 10.1.1.1 000b.5faa.51c0,
Success rate is 0 percent (0/5)
Followed by a lot of;
*Mar  1 00:13:01.431: IP ARP rep filtered src 10.1.50.1 000b.5faa.51c0, dst 10.1.50.1 ffff.ffff.ffff it's our address
I've not seen these messages in any sims I've run.
Kind regards,
Ross
PS: Many thanks for your second message about the up/down state at L2 and 3. Helps a lot!
Hello
Just to confirm this is what you have and it still doesn't work?
RTR
no shut
encapsulation dot1Q 50
ip address 10.1.1.1 255.255.255.0
ip routing
SW
interface FastEthernet0/1
description link to RTR
switchport mode trunk
interface FastEthernet0/2
description link to end host
switchport access vlan 50
switchport mode access
spanning-tree portfast
no ip routing
end host
ip  10.1.1.50
s/m 255.255.255.0
d/g 10.1.1.1
if this is still isn’t working suggest write erase the switch- delete it’s vlan.date file from flash: - reload and reconfigure then test again
Kind Regards
Paul
Hi Paul,
Ross
Thanks for the update. Glad to know that you have solved the problem and that it turned out to be faulty equipment. When faced with a problem we frequently tend to start looking for more complex causes, such as configuration mistakes. We do occasionally need to be reminded that sometimes out issues are more simple such as faulty hardware. Thanks for reminding us of this lesson.
Rick
Rick
Alan Ng'ethe
Level 3
Level 3
As mentioned by Paul, the router on a stick configuration seems okay.
Maybe, for good measure, you can try hard code the encapsulation to dot1q on the switch Fa0/1 interface. I presume its the default though
You can also paste the output of the following commands on the switch:
show vlan
show interfaces trunk
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
Hi Alan,
I believe it is the default, I'm using a 2950 switch and it doesn't have the option for the trunk to use any other protocol.
show vlan:
VLAN Name Status Ports
1 default active Fa0/3, Fa0/4, Fa0/5, Fa0/6
Fa0/7, Fa0/8, Fa0/9, Fa0/10
Fa0/11, Fa0/12, Fa0/13, Fa0/14
Fa0/15, Fa0/16, Fa0/17, Fa0/18
Fa0/19, Fa0/20, Fa0/21, Fa0/22
Fa0/23, Fa0/24
50 VLAN0050 active Fa0/2
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
50 enet 100050 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
show int trunk
Port Mode Encapsulation Status Native vlan
Fa0/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/1 1-4094
Port Vlans allowed and active in management domain
Fa0/1 1,50
Port Vlans in spanning tree forwarding state and not pruned
Fa0/1 1,50
Is there something I'm missing?
Kind regards,
Ross
I could be wrong, but I always define the native VLAN on the router's connection to the switch. Not exactly sure if it will do it by default. Two choices to try, make VLAN 50 the native VLAN on both:
R1
 encapsulation dot1Q 50 native
SW1
 switchport trunk native vlan 50
Or add a native VLAN1 interface to R1:
interface FastEthernet0/0.1
 encapsulation dot1Q 1 native
I have made some changes to your config, implement those and check if it makes a difference. Set your PC to DHCP, it should get an IP address from the router.
You are running a very old software on a very old switch, I am not sure about the defaults, but on the 2950, make sure that ip routing is disabled. Also, you might need to manually create Vlan 50 on SW1:
SW1#conf t
SW1(config)#no ip routing
SW1(config)#exit
SW1#vlan database
SW1(vlan)#vlan 50
SW1(vlan)#exit
Current configuration : 870 bytes
version 12.3
hostname R1
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 10.1.50.1
ip dhcp pool LAN
network 10.1.50.0 255.255.255.0
default-router 10.1.50.1
ip audit po max-events 100
no ip address
duplex auto
speed auto
ip address 10.1.50.1 255.255.255.0
no snmp trap link-status
interface Serial0/0
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
no ip http server
no ip http secure-server
ip classless
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
Current configuration : 1358 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW1
ip subnet-zero
no ip domain-lookup
--> no ip routing
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
--> no interface Vlan1
no ip address
no ip route-cache
--> no interface Vlan50
description TEST1
no ip address
no ip route-cache
ip http server
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
