VLAN Routing problem encountered
francisgamo
All experts, I need your help with my problem.
My set up in actual world is 1 CISCO 1841 router and Layer 3 CISCO SGE2000-G5 switch
Here are my VLANs in database. - in packet tracer only
VLAN Name                             Status    Ports
1    default                          active    Fa0/6, Fa0/7, Fa0/8, Fa0/9
                                                Fa0/10, Fa0/11, Fa0/12, Fa0/13
                                                Fa0/14, Fa0/15, Fa0/16, Fa0/17
                                                Fa0/18, Fa0/19, Fa0/20, Fa0/21
                                                Fa0/22, Fa0/23, Fa0/24, Gig1/1
                                                Gig1/2
10   Intenet                          active    Fa0/4
20   NO_INTERNET             active    Fa0/2, Fa0/3
30   PRINTERS                   active    Fa0/5
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
I configured those VLANs in cisco router via trunk/ (router on a stick configuration)
I want VLAN 10 would be the only allowed to connect to WAN, VLAN 20 to users who are not allowed to use internet and VLAN 30 for printers.
i'm planning to create another VLAN for servers as well with internet.
now here are my configuration. in packet tracer only.
ip dhcp excluded-address 77.110.87.113 - VLAN 10
ip dhcp excluded-address 192.168.1.1  - VLAN 20
ip dhcp excluded-address 192.168.1.75 - VLAN 30
ip dhcp pool vlan10
network 77.110.87.112 255.255.255.240
default-router 77.110.87.113
ip dhcp pool VLAN20
network 192.168.1.0 255.255.255.192
default-router 192.168.1.1
ip dhcp pool VLAN30
network 192.168.1.64 255.255.255.240
default-router 192.168.1.75
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 77.110.87.113 255.255.255.240
ip helper-address 77.110.87.113
ip nat inside
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.1.1 255.255.255.192
ip helper-address 192.168.1.1
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.1.75 255.255.255.240
ip helper-address 192.168.1.75
interface Serial0/0/0
ip address 10.1.1.2 255.255.255.252
ip nat outside
interface Vlan1
no ip address
shutdown
router rip
version 2
redistribute static
network 10.0.0.0
network 77.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.1 - asuming this is the ISP
end
they are working fine but could anybody tell me what would be the best configuration other that mine because i'm not sure if these configuration are correct and gonna work in actual set up.
thanks in advance
Giuseppe Larosa
Hello Francis,
NAT configuration is not complete
you would need an ACL and a NAT statement
example:
config t
access-list 101 remark NAT ACL
access-list 101 deny ip 77.110.87.112 0.0.0.0.15 192.168.1.0 0.0.0.63
access-list 101 deny ip 77.110.87.112 0.0.0.0.15 192.168.1.64 0.0.0.15
access-list 101 permit ip 77.110.87.112 0.0.0.0.15 any
ip nat inside source list 101 interface ser0/0/0 overload
Note:
also the ip helper-address commands that you have put are useless
Hope to help
Giuseppe
Giuseppe Larosa
Hello Francis,
example:
config t
Note:
Hope to help
Giuseppe
Thanks a lot for replying to my post. what does ip helper do in that statement sir? according to my friend this is just for creating dhcp.
by the way how to give cridet to every helpful answer?
Thanks in advance sir
Hello Francis,
thanks for your kind remarks.
the ip helper-address allows a router or multilayer switch to act as a DHCP relay agent.
The DHCP request message sent by clients is sent to address broadcast 255.255.255.255 and cannot be routed to another IP subnet. It can be converted by using the
ip helper-address
command under the SVI interface or router subinterface. This enables the DHCP relay function and allows to convert the unroutable DHCP requests in routable packets with a destination that is the IP address of the remote DHCP server. The DHCP relay agent network device populates an internal field with the IP address of the router subinterface on which the original DHCP request has been received (GI address). In this way the remote DHCP server can use this info to pick up a free IP address ( if any) from the appropriate DHCP pool.  The DHCP server answers to the DHCP relay agent that can send out the DHCP offer ( containing the assigned IP address)  to the client.
Your router is acting as DHCP server locally so you don't need those ip helper-address commands on router subinterfaces. Also when used the ip helper-address command contains an IP address that is not the same as that of the subinterface on which it is applied but that of a remote server.
Hope to help
Giuseppe
Thank you very much for that info Sir, your answers are really a big help for me beacuse i'm just a beginner and currently having my training in CCNA. if i encounter new problems I hope that it would still be welcomed.
regards
Francis
