05-14-2012 11:15 PM - edited 03-04-2019 04:21 PM
Hello, I have two routers. Taupo router is running RIP version2. Huntly Router is running OSPF. They are both communicating using Frame Relay.
I want to redistribute RIP routes from Taupo into Huntly. I have attached my relevant running-config details for each router.
Can anyone please tell me where I am going wrong, as this is not working.
I have also attached an image of the network. The two routers I am talking about here are on the ones on the far right hand side.
Thanks for any help.
Taupo router:
router rip
version 2
redistribute ospf 43 metric 1
network 172.26.0.0
no auto-summary
Huntly Router:
router ospf 43
log-adjacency-changes
passive-interface FastEthernet0/0
passive-interface FastEthernet0/0.15
passive-interface FastEthernet0/0.25
passive-interface FastEthernet0/0.86
network 172.26.252.4 0.0.0.3 area 0
network 172.26.15.0 0.0.0.127 area 0
network 172.26.25.0 0.0.0.127 area 0
network 172.26.86.0 0.0.0.15 area 0
ip classless
05-14-2012 11:51 PM
Hello Philip,
>> I want to redistribute RIP routes from Taupo into Huntly OSPF
in your current configuration you are actually doing the opposite:
router rip
version 2
network 172.26.0.0
no auto-summary
you are redistributing OSPF routes from OSPF process-id 43 into RIP with a seed metric of 1.
if you want to redistribute RIP routes into OSPF you need to do the following:
router rip
no redistribute ospf 43
router ospf 43
redistribute rip subnets metric 50
Note: the subnets keyword is important to avoid an automatic summarization to major networks ( Class A, B.C) that OSPF would do otherwise.
First router has to be OSPF neighbor of the second router on the interface connecting the two device.
if so this change is enough
redistribute command has to be configured under the protocol that will receive the routes and not under the protocol that is exporting the routes.
Hope to help
Giuseppe
05-15-2012 12:08 AM
Thank you Giuseppe, that is very good information, but I still canot get it to work.
Can you see what I am doing wrong below ? I made some changes based on what you told me.
This is my router that is running OSPF. I want this router to receive RIP subnets from the other router:
router ospf 43
redistribute rip metric 50 subnets
ip classless
This is my second router that is running RIP. I want this router to send it's RIP routes to the first router above:
router rip
version 2
network 172.26.0.0
no auto-summary
ip classless
05-15-2012 12:20 AM
the redistribution router MUST run the 2 protocols otherwise it can't redistribute aand from your config snippets I don't see any RIP configured on Huntly.
Then you won't see the redistributed routes on the redistribution router but on a router which is in the routing domain you are redistributing into.
They will appear as OE2 routes on Hamilton and Waii if they run OSPF.
Regards.
Alain
05-15-2012 12:52 AM
Hello Philip,
====> so it must run RIP too, and to have a common link with the other router to become RIP neighbor, and to receive the RIP routes
A router running both routing protocols is needed that will act as ASBR, (Autonomous system Boundary Router) sort of translator.
You cannot translate from french to english if you don't speak both!
Hope to help
Giuseppe
