VLAN setup question
jowen3400
Ok I am doing something really dumb and I should be able to see it.  But been working on this for 4 days now and I just give up
More or less this is the running-config.   What I need is VLAN 1 to be 192.168.0.0 network and the Wireless to conenct to it as well as wired PC's.  I also need the internet access as well.  But some reason I can't find where I am messing up at.
uilding configuration...
Current configuration : 9785 bytes
! Last configuration change at 22:56:02 PCTime Thu Jan 5 2006 by jowen
version 15.1
no service pad
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 owFjOrjW38M9WMkNbFbcjCTRoDvrT.fnTRH/fHsW6eM
no aaa new-model
memory-size iomem 10
clock timezone PCTime -6 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-1200490230
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1200490230
revocation-check none
rsakeypair TP-self-signed-1200490230
ip source-route
ip port-map http port tcp 5222 list 1 description something
ip port-map https port tcp 80 list 3 description Surveilance
ip port-map https port udp 5060 list 2 description something
ip port-map https port udp 4569 list 4 descriptionsomething
ip port-map https port tcp 5269 list 5 description Chat
ip port-map https port tcp 443 list 6 description Mobile
ip port-map https port tcp from 10000 to 20000  list 7 description RT
ip port-map https port tcp from 4000 to 4031  list 8 description MobileR
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.10.1 192.168.10.199
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool <name1>
import all
network 192.168.10.0 255.255.255.0
dns-server 66.180.96.12 192.168.0.116
ip dhcp pool Guests
import all
network 192.168.200.0 255.255.255.0
dns-server 8.8.8.8
no ip cef
ip domain name yourdomain.com
ip name-server 66.180.96.12
ip ftp username cisco
ip ftp password cisco
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any CCP_PPTP
match class-map SDM_GRE
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol pptp
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any FONHUD
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any Video
match protocol tcp
class-map type inspect match-all ccp-cls-ccp-permit-2
match class-map Video
match access-group name Surveilance
class-map type inspect match-all ccp-cls-ccp-permit-1
match class-map FONHUD
match access-group name FONHUD
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class type inspect ccp-cls-ccp-permit-2
  inspect
class type inspect ccp-cls-ccp-permit-1
  inspect
class class-default
  drop
policy-map type inspect ccp-pol-outToIn
class type inspect CCP_PPTP
  pass
class class-default
  drop log
zone security in-zone
zone security out-zone
zone security DMZ
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-zone-To-in-zone source out-zone destination in-zone
service-policy type inspect ccp-pol-outToIn
zone-pair security ccp-zp-out-self source out-zone destination self
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description $FW_OUTSIDE$$ETH-WAN$
ip address xx.xx.xxx.194 255.255.255.252
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 192.168.100.1 255.255.255.0
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
description $FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
zone-member security in-zone
interface Vlan2
ip nat inside
zone-member security DMZ
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export destination 192.168.0.59 2055
ip nat pool OPSOffice 192.168.0.20 192.168.0.200 netmask 255.255.255.0
ip nat inside source list 9 interface FastEthernet4 overload
ip nat inside source list 199 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip route 192.168.0.0 255.255.255.0 Vlan1 dhcp
ip route 192.168.1.0 255.255.255.0 Vlan2 dhcp
ip access-list extended FONHUD
remark CCP_ACL Category=128
permit ip any host 192.168.0.117
ip access-list extended SDM_GRE
permit gre any any
ip access-list extended Surveilance
permit ip any host 192.168.0.74
access-list 1 remark CCP_ACL Category=1
access-list 1 permit 192.168.0.117
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.0.117
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 192.168.0.74
access-list 4 remark CCP_ACL Category=1
access-list 4 permit 192.168.0.117
access-list 5 remark CCP_ACL Category=1
access-list 5 permit 192.168.0.117
access-list 6 remark CCP_ACL Category=1
access-list 6 permit 192.168.0.117
access-list 7 remark CCP_ACL Category=1
access-list 7 permit 192.168.0.117
access-list 8 remark CCP_ACL Category=1
access-list 8 permit 192.168.0.117
access-list 9 remark CCP_ACL Category=2
access-list 9 permit 10.10.10.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 69.15.113.192 0.0.0.3 any
access-list 199 permit ip any any
no cdp run
snmp-server ifindex persist
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
access-class 23 in
exec-timeout 40 0
privilege level 15
password telnet
login local
transport input telnet ssh
end
Markus Thun
In your configuration is the vlan 1 set to " ip address 10.10.10.1 255.255.255.0" . Has the router another way to 192.168.0.0 or should u connect the router to the subnet 192.168.0.0 ?
If u want vlan 1 to 192.168.0.0 use this command:
interface vlan 1
ip add 192.168.0.1 255.255.255.0
Do not forget the vlan binding on the physical interface!
Markus
