04-24-2023 01:35 PM
From my understanding, using subinterfaces here would normally be the best way to pass VLAN tagged traffic across the T1 over trunked ports, however subinterfaces are built off physical ports. The ISR4221 routers have T1 modules in them, forcing us to use virtual serial interfaces. Currently the AP (VLAN1) can ping all the way through and vice versa. How can I get the hosts on VLANS working across the network. The subnet is assigned at the FW. Thank you in advance for any advice!
04-24-2023 01:46 PM
use VPWS and then run VLAN tag frame over it.
04-24-2023 02:15 PM
Thank you, I'll research and give it a shot!
04-24-2023 02:44 PM
Unclear why you need to pass you VLANs across the T1. In other words why does SW1 need to "see" SW2 VLANs or the converse?
Normally, once VLANs hit a router, packets would be handled strictly at L3.
04-25-2023 05:32 AM - edited 04-25-2023 05:42 AM
Maybe I'm overcomplicating it? The Meraki AP has 2 SSID's, both tagged with a different vlan, which is plugged into a trunk port on the switch, then trunk port to router (same on other side). The hosts, when trying to connecting to the AP on either SSID, will not ping through or see the FW to get an IP from the DHCP scope on the FW.
04-25-2023 07:30 AM - edited 05-09-2023 07:53 AM
Well, just found that I had no VLANS on SW2, added them and same result, the AP clients will not get a response from the DHCP server.
