VLAN
saquib.tandel
Hello
Can I get some assistance
Site_A connects to Site_B via outdoor wireless.
Wireless link terminates on 4500 on both Sites
How can I extend the VLAN5 on Site_B (Vlan5 is defined on Site_A)
I need to connect 3 server on Site_B with vlan5
((( Site_A )))
vlan 5
description Server
ip address 192.168.1.0 255.255.255.0
vlan6
ip address 192.168.2.0 255.255.255.0
vlan10
description connected to site_B
ip address 10.10.10.1 255.255.255.252
router ospf 5
network 192.168.1.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
network 10.10.10.0 0.0.0.3 area 0
interface fa 0/20
switchport mode access
switchport access vlan10
((( Site_B )))
vlan 12
ip address 192.168.10.0 255.255.255.0
vlan13
ip address 192.168.11.0 255.255.255.0
vlan10
description connected to site_A
ip address 10.10.10.2 255.255.255.252
router ospf 5
network 192.168.10.0 0.0.0.255 area 0
network 192.168.11.0 0.0.0.255 area 0
interface fa 1/0/20
Ganesh Hariharan
Hello
((( Site_A )))
vlan 5
description Server
vlan6
vlan10
router ospf 5
interface fa 0/20
((( Site_B )))
vlan 12
vlan13
vlan10
router ospf 5
interface fa 1/0/20
Hi Saquib,
You have configured ports between site A and site B as access port conigure these ports as trunk port and allow the vlan 5 to move over the trunk then you can have vlan 5 in site B also.
Check out the below link how to configure a trunk port in switches
http://www.ciscosystems.com/en/US/docs/switches/lan/catalyst4000/8.2glx/quick/software/guide/trunks.html#wp1015075
Hope to help
If helpful do rate the post
Ganesh.H
Hello Ganesh
Is it recommended to run TRUNK over bridge connection, anything to watchout with this change.
ST
Hello Ganesh
ST
Hi ST,
As such there is no recommendation it is just another configuration to support the need for extending vlan over to another switch just take care of the following things while conifiguring trunk in switches.
By default, Fast Ethernet and Gigabit Ethernet ports are in auto mode. If the port on the other end of the link is in desirable mode or on, a port in auto mode automatically becomes a trunk port.
What the default trunk encapsulation is depends on which encapsulation the hardware supports:
•negotiate (on hardware supporting both ISL and 802.1Q)
•isl (on hardware supporting ISL only)
•dot1q (on hardware supporting 802.1Q only)
Ganesh.H
