Vlans on layer 3 switch not capable of accessing ISP modem/router
cdubbcisco1
I have a Cisco 3560 switch with IP routing and multiple vlans setup.
Hosts can communicate between vlans like I want but hosts within these different vlans have to be able to access the INTERNET and they cannot access the ISP's VDSL router/modem.
here is the switch config.
no aaa new-model
system mtu routing 1500
vtp domain Church
vtp mode transparent
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 10
name Management
vlan 20
name Church_Office
vlan 30
name School
interface FastEthernet0/1
switchport access vlan 20
switchport mode access
interface FastEthernet0/18
description To ISP_Modem_Router
no switchport
ip address 192.168.99.2 255.255.255.0
interface FastEthernet0/31
switchport access vlan 30
spanning-tree portfast
interface FastEthernet0/47
switchport access vlan 10
spanning-tree bpduguard enable
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.200.1 255.255.255.0
interface Vlan20
interface Vlan30
ip address 192.168.0.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.99.1
ip http server
control-plane
line con 0
password 7 104A281724033D065C52
login
line vty 0 4
login
line vty 5 15
login
end
Interface Fast Ethernet 0/18 on the Cisco 3560 switch is plugged into the ISP's modem/router which is basically just a switch LAN ports on the back of the
DSL modem/router.
I can ping the ISP modem/router from the 3560 switch and the hosts within the Vlans can ping 192.168.99.1 interface on the switch with is the uplink to the ISP's modem/router but they cannot ping the modem itself.
The problem I believe is that there are no static route statements back to the 3560 from the ISP router and also the fact that the port on the ISP router is not actually a routed port but just a LAN port and this is why it is not working.
Does this sound correct and if so......what are my options?
I am assuming I would need a cisco router in between the ISP's modem/router and the 3560 cisco switch:.... and I would have to setup  either  subinterfaces and dot1q trunking  to the 3560 switch or static route statements back to the 3560 switch for this to work.
Do this sound correct or is there some how some way to make this work with the equipment I currently have?
Thanks in advance.
Bilal Nawaz
Hello, you are correct, there is no route back as the modem does not know about your internal networks.
You need to set up NAT on your router/switch. Not sure if the switch can do NAT, I'm assuming it can't hence you would need a router. You don't necessarily have to do a router on a stick with creating a trunk etc...
On the switch you can set a default route to the router and from the router a default to the modem. So all could be layer 3 routing.
Then the router can do the NAT.
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/260-cisco-router-nat-overload.html
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
5 Replies 5
Bilal Nawaz
Hope this helps
I know the switch won't do NAT so when you say that the router would need to do NAT I would need to purchase a router to put between my cisco 3560 and the ISP's modem/router?
Does that sound correct?
Yes. This is what I would do and seems the only way to do NAT, which is required in this scenario.
Hope this helps
Dear cdubb,
How did u resolve this issue?
I am having the same setup with a 3560-x and am stuck.
Do you mind giving me the setup commands?
Seems your isp modem/router is natting already given the ip adrress you have setup on the 3650 wan interface(isp lan interface) so my question is - are you able to confiure this modem/router to cider off private address into different subnets
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
