Vlans on switch 3560 layer 3 is not able to access the internet
I have a Cisco Catalyst 3560-CX switch and an RV320 router.
I am trying to configure my router only for VPN and the switch in layer 3, I have 3 Vlan: Vlan 2 (wireless data), vlan 3 (VoIP server) and Vlan 4 (NAS and web server), but I still can't ping with my router gateway rv320.
when I ping from the command line from switch 3560, I can ping 8.8.8.8 or any ip in the world, including vlan 2, 3, 4 and its devices (laptop, pc's, iphone, etc, NAS, SERVER). when I try to ping from my laptop in vlan 2 I can only ping the other vlans (vlan 3, vlan 4) but not at ip 192.168.1.100 and much less at 192.168.1.1 or internet
I have configured on router RV320
WAN ip: 10.0.0.2 static
working mode: gateway
LAN ip: 192.168.1.1
I have configured on the switch L3
ip routing
vlan 2
name Wireless
vlan 3
name VoIP
vlan 4
name NAS
int vlan 1
no ip add
shut
Int vlan 2
ip add 172.16.2.1 255.255.255.0
no shut
Int vlan 3
ip add 172.16.3.1 255.255.255.0
no shut
Int vlan 4
ip add 172.16.4.1 255.255.255.0
no shut
service dhcp
ip dhcp pool vlan2
netw 172.16.2.0 255.255.255.0
default-router 172.16.2.1
ip dhcp pool vlan3
netw 172.16.3.0 255.255.255.0
default-router 172.16.3.1
ip dhcp pool vlan4
netw 172.16.4.0 255.255.255.0
default-router 172.16.4.1
int gi0/1
switc mode acc
switc acc vlan 2
no shut
int gi0/3
switch mode acc
switch acce vlan 4
ip route 0.0.0.0 0.0.0.0 192.168.1.1
int gi0/9
no switch
ip add 192.168.1.100
no shut
PLEASE HELP
14 Replies 14
Your switch configuration looks good as far as you PING from the switch since it uses the interface connected with the router to send out icmp packets. However, when you PING from any of the VLANs, there is no return route on the Router side (the router does not know how to get back to those networks). There are two alternatives to resolve this issue:-
1) Configure NAT on the LAN side; that is, translate IP addresses from the different VLANs to 192.168.1.100. Unfortunately, you can not do that as 3560 is a switch and it does not support NAT configuration.
2) Configure either static or dynamic routing protocol on the switch and the router, and advertise those routes to the router.
HTH,
Meheretab
HTH,
Meheretab
I appreciate your help and prompt response. This is my most accurate information of what I have configured on my switch. I attach the configuration
I tried to make the indications you recommended but I still don't find a positive response
Configure RIp V2 protocol on the router and on the switch
thanks for your help
Hello
On the rtr
ip route 172.16.2.0 255.255.255.0 192.168.1.100
ip route 172.16.3.0 255.255.255.0 192.168.1.100
ip route 172.16.4.0 255.255.255.0 192.168.1.100
ip route 0.0.0.0 0.0.0.0 xxxx<wan interface> 10.0.0 x <wan nexthop>
int xx
Description lan facing interface
ip nat inside
int xx
Description WAN facing interface
ip nat outside
access-list 10 permit 172.16.2.0 0.0.0.255
access-list 10 permit 172.16.3.0 0.0.0.255
access-list 10 permit 172.16.4.0 0.0.0.255
ip nat inside source list 10 interface xx<wan interface>
Kind Regards
Paul
I cannot enter configuration because it is an RV320 router
however enter this configuration on the router
as far as I recall, the RV320 has only a few commands available through the command line (CLI), so you probably have to configure it through the WebGUI. As suggested, the easiest would be to configure RIPv2 between the RV320 and the 3560. On the RV320, see Step 2 on page 38 of the attached user guide for the procedure to enable RIP.
As for granting access to the Internet to all your others Vlans, I think you have to add the additonal networks under Setup --> Network (page 15 of the user guide). There is no setting to manually add these new networks to be natted, so I assume it automatically translates all the networks that you add...not sure if it works like that though...
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/administration/guide/en/Updated/rv32x_ag_en.pdf
Hello
make some configurations that are the following attached, if you take a look and tell me your opinion.
thank you
The configuration is looking good but you are using two routings as static/default and RIP.  Here, Static/Default routing is taking over the RIP due to higher AD value.
I want to know what is IP on the Eth0 on the router? Is it 192.168.1.1?
You had configured static routes on the Router which is also looking some confusion: static route.png
Static route: 172.16.0.0 /16
and to two more routes as: 172.16.2.0/24, and 172.16.3.0/24
There will no issue but looking at incorrect entry.
One issue I found with RIP configuration on the switch as:
router rip
 version 2
 network 10.0.0.0
 network 172.16.0.0
 network 192.168.1.0
Network 10.0.0.0 is directly connected to the router so it must be removed from the switch configuration and new configuration
router rip
 version 2
 network 172.16.0.0
 network 192.168.1.0
and you have selected "Gateway" on the router configuration so I am assuming that router is redistributing default route in the RIP.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Do you think and recommend that I delete the static routes and let the RIP protocol do the job?
if you mean my gateway? yes, it's my gateway 192.168.1.1
on my WAN1 is the IP 10.0.0.2 and my WAN1 gateway is 10.0.0.1
You had configured static routes on the Router which is also looking some confusion:static route.png
I did this because I wanted to redirect the IP addresses to my internal networks via 192.168.1.101 which is the port of my gi0 / 9 switch, did I do it correctly? but if I'm wrong, please don't hesitate to tell me
and about the switch I already made the corrections, that if indeed it was wrong. just a question:
Do you recommend that I continue on "working mode: gateway" or "working mode: router"?
I add some additional information
MacBook-Pro-de-Alejandro:~ Alejandro$ ping 172.16.2.1
PING 172.16.2.1 (172.16.2.1): 56 data bytes
64 bytes from 172.16.2.1: icmp_seq=0 ttl=255 time=2.356 ms
64 bytes from 172.16.2.1: icmp_seq=1 ttl=255 time=3.383 ms
64 bytes from 172.16.2.1: icmp_seq=2 ttl=255 time=2.990 ms
64 bytes from 172.16.2.1: icmp_seq=3 ttl=255 time=4.156 ms
64 bytes from 172.16.2.1: icmp_seq=4 ttl=255 time=2.490 ms
64 bytes from 172.16.2.1: icmp_seq=5 ttl=255 time=3.375 ms
^C
--- 172.16.2.1 ping statistics ---
6 packets transmitted, 6 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 2.356/3.125/4.156/0.606 ms
MacBook-Pro-de-Alejandro:~ Alejandro$ ping 172.16.2.4
PING 172.16.2.4 (172.16.2.4): 56 data bytes
64 bytes from 172.16.2.4: icmp_seq=0 ttl=64 time=35.676 ms
64 bytes from 172.16.2.4: icmp_seq=1 ttl=64 time=58.862 ms
64 bytes from 172.16.2.4: icmp_seq=2 ttl=64 time=77.678 ms
64 bytes from 172.16.2.4: icmp_seq=3 ttl=64 time=100.598 ms
64 bytes from 172.16.2.4: icmp_seq=4 ttl=64 time=18.140 ms
^C
--- 172.16.2.4 ping statistics ---
5 packets transmitted, 5 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 18.140/58.191/100.598/29.290 ms
MacBook-Pro-de-Alejandro:~ Alejandro$ ping 172.16.3.1
PING 172.16.3.1 (172.16.3.1): 56 data bytes
64 bytes from 172.16.3.1: icmp_seq=0 ttl=255 time=2.549 ms
64 bytes from 172.16.3.1: icmp_seq=1 ttl=255 time=2.634 ms
64 bytes from 172.16.3.1: icmp_seq=2 ttl=255 time=3.744 ms
64 bytes from 172.16.3.1: icmp_seq=3 ttl=255 time=3.222 ms
64 bytes from 172.16.3.1: icmp_seq=4 ttl=255 time=3.820 ms
64 bytes from 172.16.3.1: icmp_seq=5 ttl=255 time=3.590 ms
^C
--- 172.16.3.1 ping statistics ---
round-trip min/avg/max/stddev = 2.549/3.260/3.820/0.509 ms
MacBook-Pro-de-Alejandro:~ Alejandro$ ping 172.16.3.2
PING 172.16.3.2 (172.16.3.2): 56 data bytes
64 bytes from 172.16.3.2: icmp_seq=0 ttl=63 time=1.091 ms
64 bytes from 172.16.3.2: icmp_seq=1 ttl=63 time=2.076 ms
64 bytes from 172.16.3.2: icmp_seq=2 ttl=63 time=1.730 ms
64 bytes from 172.16.3.2: icmp_seq=3 ttl=63 time=2.218 ms
64 bytes from 172.16.3.2: icmp_seq=4 ttl=63 time=2.023 ms
64 bytes from 172.16.3.2: icmp_seq=5 ttl=63 time=1.946 ms
^C
--- 172.16.3.2 ping statistics ---
round-trip min/avg/max/stddev = 1.091/1.847/2.218/0.369 ms
MacBook-Pro-de-Alejandro:~ Alejandro$ ping 192.168.1.101
PING 192.168.1.101 (192.168.1.101): 56 data bytes
64 bytes from 192.168.1.101: icmp_seq=0 ttl=255 time=3.603 ms
64 bytes from 192.168.1.101: icmp_seq=1 ttl=255 time=2.484 ms
64 bytes from 192.168.1.101: icmp_seq=2 ttl=255 time=2.752 ms
64 bytes from 192.168.1.101: icmp_seq=3 ttl=255 time=3.506 ms
64 bytes from 192.168.1.101: icmp_seq=4 ttl=255 time=4.275 ms
64 bytes from 192.168.1.101: icmp_seq=5 ttl=255 time=5.880 ms
64 bytes from 192.168.1.101: icmp_seq=6 ttl=255 time=5.118 ms
64 bytes from 192.168.1.101: icmp_seq=7 ttl=255 time=3.626 ms
^C
--- 192.168.1.101 ping statistics ---
8 packets transmitted, 8 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 2.484/3.905/5.880/1.072 ms
PING 192.168.1.1 (192.168.1.1): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
^C
--- 192.168.1.1 ping statistics ---
7 packets transmitted, 0 packets received, 100.0% packet loss
can the clients in Vlan 2 and 3 ping the default gateway on the RV320 (192.168.1.1) ?
no! I can not
but from my switch if I can
^C
^C
^C
^C
^C
^C
First Make some configuration changes on the Switch as:
ip dhcp pool Vlan2
network 172.16.2.0 255.255.255.0
no dns-server 172.16.2.1
dns-server 8.8.8.8
ip dhcp pool Vlan3
network 172.16.3.0 255.255.255.0
no dns-server 172.16.3.1
dns-server 8.8.8.8
Because your switch is not working as a DNS forwarder.
Please share a screenshot of the router Firewall configuration and NATing configuration (Port Address Translation).
Deepak Kumar,
thank you for helping me
At this time I just changed the switch configuration about DNS and attached the images of my router
regards
Alejandro
Disable the Router firewall and try to ping the firewall address and run a traceroute command from the PC to address 192.168.1.1 and 8.8.8.8
Deepak Kumar,
thanks again and sorry for the delay in responding
I have disabled my router's firewall, made the DNS 8.8.8.8 changes and traceroute and this was the results.
I'm still with the same problem I don't get internet access in my Vlan
thanks for giving me your help
