02-02-2014 01:30 AM - edited 03-04-2019 10:14 PM
Hi all,
Does somebody know what mean messages below? I didn't find any information about it.
*Jan 31 06:36:08.393: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (9/10).
*Jan 31 06:36:38.393: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Proceeding with best-effort installation.
The messages appear during ASR booting:
Initializing Hardware ...
Calculating the ROMMON CRC ... CRC is correct
System Bootstrap, Version 15.0(1r)S, RELEASE SOFTWARE
Copyright (c) 1994-2010 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: PowerOn
ASR1000-1RU platform with 8388608 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Warning: filesystem is not clean
File size is 0x176a9d2c
Located asr1001-universalk9.03.08.01.S.153-1.S1.bin
Image size 392863020 inode num 12, bks cnt 95914 blk size 8*512
Boot image size = 392863020 (0x176a9d2c) bytes
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated 84a3666c:bedce04a:c78e680a:156d1948:6ec6a994
expected 84a3666c:bedce04a:c78e680a:156d1948:6ec6a994
Image validated
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): prep_storage took: 11 seconds, expected max time 10 seconds
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): Chasfs initialisation took: 20 seconds, expected max time 10 seconds
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.3(1)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 08-Feb-13 10:26 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Warning: the compile-time code checksum does not appear to be present.
cisco ASR1001 (1RU) processor with 3803482K/6147K bytes of memory.
Processor board ID SSI17360CLL
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
7741439K bytes of eUSB flash at bootflash:.
Press RETURN to get started!
*Jan 31 06:31:42.406: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = asr1001 Next reboot level = ipbase and License = No valid license found
*Jan 31 06:31:43.703: %IOSXE_THROUGHPUT-6-LEVEL: Throughput level has been set to 2500000 kbps
*Jan 31 06:31:51.131: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jan 31 06:31:51.131: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jan 31 06:31:51.855: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jan 31 06:31:51.922: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jan 31 06:31:51.933: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jan 31 06:31:52.154: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jan 31 06:31:52.154: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jan 31 06:31:52.233: %DYNCMD-7-CMDSET_LOADED: The Dynamic Command set has been loaded from the Shell Manager
*Jan 31 06:31:46.534: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 36000000 kbps
*Jan 31 06:31:49.403: %CPPHA-7-START: SIP0: cpp_ha: CPP 0 preparing image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/qfp-ucode-1ru
*Jan 31 06:31:49.613: %CPPHA-7-START: SIP0: cpp_ha: CPP 0 startup init image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/qfp-ucode-1ru
*Jan 31 06:31:52.319: %DYNCMD-7-PKGINT_INSTALLED: The command package 'platform_trace' has been succesfully installed
*Jan 31 06:31:53.069: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jan 31 06:31:53.071: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jan 31 06:31:53.161: %SYS-5-CONFIG_I: Configured from memory by console
*Jan 31 06:31:53.169: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jan 31 06:31:53.172: %SPA_OIR-6-OFFLINECARD: SPA (ASR1001) offline in subslot 0/0
*Jan 31 06:31:53.178: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jan 31 06:31:53.178: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jan 31 06:31:53.178: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jan 31 06:31:53.178: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jan 31 06:31:53.186: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jan 31 06:31:54.120: %CPPHA-7-START: SIP0: cpp_ha: CPP 0 running init image /tmp/sw/fp/0/0/fp/mount/usr/cpp/bin/qfp-ucode-1ru
*Jan 31 06:31:54.370: %CPPHA-7-READY: SIP0: cpp_ha: CPP 0 loading and initialization complete
*Jan 31 06:31:54.609: %IOSXE-6-PLATFORM: SIP0: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
*Jan 31 06:31:54.860: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Jan 31 06:31:57.359: %SPA_OIR-6-ONLINECARD: SPA (ASR1001) online in subslot 0/0
*Jan 31 06:31:57.310: %LINK-3-UPDOWN: SIP0/0: Interface EOBC0/1, changed state to up
*Jan 31 06:31:59.754: %IOSXE-5-PLATFORM: SIP0: xinetd[11876]: xinetd Version 2.3.14 started with no options compiled in.
*Jan 31 06:31:59.754: %IOSXE-5-PLATFORM: SIP0: xinetd[11876]: Started working: 1 available service
*Jan 31 06:31:59.773: %IOSXE-5-PLATFORM: SIP0: xinetd[11879]: xinetd Version 2.3.14 started with no options compiled in.
*Jan 31 06:31:59.773: %IOSXE-5-PLATFORM: SIP0: xinetd[11879]: Started working: 3 available services
*Jan 31 06:32:08.394: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (1/10).
*Jan 31 06:32:38.393: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (2/10).
*Jan 31 06:33:08.394: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (3/10).
*Jan 31 06:33:38.393: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (4/10).
*Jan 31 06:34:08.393: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (5/10).
*Jan 31 06:34:38.393: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (6/10).
*Jan 31 06:35:08.393: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (7/10).
*Jan 31 06:35:38.393: %VMAN-5-INSTALL_MEDIA_RETRY: SIP0: vman: VMAN VM install media still unavailable. Attempt (8/10).
*Jan 31 06:36:49.346: %NETCLK-5-NETCLK_MODE_CHANGE: Network clock source not available. The network clock has changed to freerun
11-04-2015 02:22 PM
