Voice VLAN, QoS, ISR subinterface, outbound calls
leam2
Hello.
I have phones on VLAN 100 with QoS platinum and a LAN subinterface Gi0/0/1.100 on an ISR.
There is also a WAN subinterface Gi0/0/1.835 on the ISR with "encapsulation dot1Q 835" which is a requirement from the ISP.
I cannot make outbound calls and I was wondering maybe it's because of the 100 tag on the frames coming from the phones.
Can you enlighten me?
a.alekseev
Level 7
Level 7
unlikely
check the routing....
Ok. Thanks.
Can you please be super kind and helpful and tell me how to check the routing?
I have noticed in the output of "show dial-peer voice" the "no route to destination" message:
        Successful Calls = 0, Failed Calls = 16, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Bandwidth CAC Accepted Calls = 0, Bandwidth CAC Refused Calls = 0,
        Last Disconnect Cause is "3   ",
        Last Disconnect Text is "no route to destination (3)",
And also from "show sip-ua statistics", I get these messages:
SIP Global Counters:
  <File Id,   Line:  Count    First Occurence         Most Recent Occurence Message>
    0x7   , 2323  : 2343      Jul 05 2018 15:33:31    Jul 06 2018 11:23:02 Corrupted/Freed Container=%p
    0xC   , 227   : 2422      Jul 05 2018 14:32:45    Jul 06 2018 18:30:37 Freeing NULL pointer!
    0xC   , 2738  : 1         Jul 05 2018 14:08:03    Jul 05 2018 14:08:03 Found header %s into static table
    0x12  , 1111  : 578       Jul 05 2018 14:46:33    Jul 06 2018 18:29:39 DNS Query failed for query_type:%d
    0x12  , 1200  : 2346      Jul 05 2018 15:33:31    Jul 06 2018 11:24:34 act_sent_register_wait_100: Out of retries
    0x13  , 485   : 5         Jul 05 2018 14:35:55    Jul 06 2018 11:35:42 RCB with mac [%s] has been removed
    0x13  , 649   : 7         Jul 05 2018 14:30:29    Jul 06 2018 11:35:42 No entry found in sipCallID Table
    0x13  , 732   : 5         Jul 05 2018 14:35:55    Jul 06 2018 12:15:27 Entry not found for search key
    0x13  , 753   : 6         Jul 05 2018 15:32:24    Jul 06 2018 11:24:26 No entry found in ccCallID Table
    0x13  , 861   : 17        Jul 05 2018 14:32:45    Jul 06 2018 12:15:27 No entry found in reg Number Table for %s
    0x13  , 1126  : 5         Jul 05 2018 14:35:55    Jul 06 2018 12:15:27 No entry found in ccCallID Table
    0x13  , 1712  : 4         Jul 05 2018 14:30:29    Jul 05 2018 14:36:59 ***No entry found in Destination pattern Table
    0x17  , 4081  : 15        Jul 05 2018 14:52:01    Jul 06 2018 18:30:37 DNS Query failed for query_type:%d
    0x17  , 4153  : 6         Jul 06 2018 12:46:32    Jul 06 2018 14:13:02 sipSPIGetNextDestHost failed  Invalid DNS entries received
    0x17  , 14204 : 51        Jul 05 2018 14:51:59    Jul 06 2018 18:30:37 Out of retries
    0x1A  , 1433  : 1         Jul 06 2018 11:52:38    Jul 06 2018 11:52:38 Could not find matching transaction for this  response
    0x1D  , 1895  : 1         Jul 06 2018 14:37:18    Jul 06 2018 14:37:18 No conn_index present for listen sock
    0x21  , 2726  : 3183      Jul 05 2018 14:30:29    Jul 06 2018 18:30:37 Invalid deferredQueue
    0x21  , 3075  : 2         Jul 05 2018 14:37:15    Jul 05 2018 14:39:06 invalid ccb, bName or branch list for sipSPIRemoveBranchName
    0x21  , 4493  : 29        Jul 05 2018 14:37:15    Jul 06 2018 18:30:37 No Inbound Container Created !!!
    0x21  , 4531  : 29        Jul 05 2018 14:37:15    Jul 06 2018 18:30:37 No Inbound Container Created !!!
    0x21  , 7702  : 6         Jul 06 2018 12:46:32    Jul 06 2018 14:13:02 resolve_sig_ip_address_to_bind failed
    0x24  , 605   : 75        Jul 05 2018 14:30:29    Jul 06 2018 18:30:34 Invalid parameters
    0x27  , 8123  : 13        Jul 05 2018 14:30:29    Jul 06 2018 11:35:42 ReqLine IP addr does not match with host IP addr
    0x2D  , 97    : 593       Jul 05 2018 14:46:33    Jul 06 2018 18:30:37 DNS Query for %s failed
    0x30  , 13693 : 22        Jul 05 2018 14:51:58    Jul 06 2018 18:30:34 ccb->src_addr_str is NULL
    0x35  , 7527  : 29        Jul 05 2018 14:37:15    Jul 06 2018 18:30:37 Container is NULL
    0x35  , 8464  : 5         Jul 05 2018 14:35:55    Jul 06 2018 12:15:27 Null ContentQ - Exit
    0x41  , 695   : 35        Jul 05 2018 14:32:45    Jul 06 2018 18:30:34 main stream, No DNS involved
    0x41  , 791   : 35        Jul 05 2018 14:32:45    Jul 06 2018 18:30:34 resolve_sig_ip_address_to_bind failed
    0x41  , 7643  : 222       Jul 05 2018 14:32:45    Jul 06 2018 18:30:34 Unexpected VoIPCodec Type :%s
    0x41  , 18849 : 35        Jul 05 2018 14:32:45    Jul 06 2018 18:30:34 Failed to get source addres for IPv4 stream
    0x4F  , 1004  : 2924      Jul 05 2018 14:46:33    Jul 06 2018 18:29:39 Message Code Class %dxx Method Code %d received for REGISTER
    0x4F  , 1143  : 2343      Jul 05 2018 15:33:31    Jul 06 2018 11:23:02 SIP Registration Retries Exhausted
    0x4F  , 5131  : 2         Jul 05 2018 14:35:55    Jul 05 2018 14:36:15 SIP register Error : Invalid args in unreg
    0x50  , 842   : 22        Jul 05 2018 14:51:58    Jul 06 2018 18:30:34 media_src_address is NULL; c-line is not added
    0x57  , 861   : 1         Jul 06 2018 12:45:21    Jul 06 2018 12:45:21 resolve_ip_address_to_bind() failed
    0x5A  , 4490  : 18        Jul 06 2018 12:46:32    Jul 06 2018 14:13:02 bind interface address not available
    0x5A  , 4566  : 18        Jul 06 2018 12:46:32    Jul 06 2018 14:13:02 Invalid dialpeer bind media config
    0x5A  , 4977  : 36        Jul 06 2018 12:46:22    Jul 06 2018 14:13:02 Dialpeer bind configured, interface addr failure
    0x5A  , 12319 : 2         Jul 05 2018 14:37:15    Jul 05 2018 14:39:06 Failed AV set
    0x64  , 2362  : 1         Jul 06 2018 14:37:18    Jul 06 2018 14:37:18 No conn_index present for listen sock
Please help because I'm going round in circles.
