Shutdown BGP Neighbor
johnlloyd_13
Level 9
Level 9
hi,
i'll be doing a maintenance on our iBGP peering for MPLS VPN/VRF exchanged routes.
just to confirm, i just 'shutdown' a BGP neighbor and it will also 'shutdown' the configured address family.
sample below:
router bgp 65000
 neighbor 1.1.1.1 shutdown
address-family vpnv4
 neighbor 1.1.1.1 activate
address-family vpnv6
to 'unshut' i just do a 'no' on the neighbor command?
this will not REMOVE the neighbor command and AF config it's associated with?
router bgp 65000
 no neighbor 1.1.1.1 shutdown
mvsheik123
Level 7
Level 7
Hi John,
You are correct - no neighbor command should do the trick. Below is from BGP command ref:
neighbor shutdown
To disable a neighbor or peer group or to gracefully shut down a link for maintenance, use theneighbor shutdown command in router configuration mode or address family configuration mode. To reenable the neighbor or peer group, use the no form of this command.
neighbor { ip-address | peer-group-name } shutdown graceful seconds [ community value] [ local-preference value ] [ community value ] [ local-preference value]
no neighbor { ip-address | peer-group-name } shutdown graceful seconds [ community value] [ local-preference value ] [ community value ] [ local-preference value]
Good luck with the maintenance.
hth
MS
mvsheik123
Level 7
Level 7
Hi John,
neighbor shutdown
hth
MS
