Voice VLAN
saquib.tandel
What is the difference between these options, and which one is recommended over the other.
Considering single cable connecting from Switch to phone to PC
### Edge switch - config
#1
int fa 0/1
switchport trunk encap dot 1q
switchport mode trunk
switchport trunk allowed vlan 2,12
#2
int fa 0/1
switchport mode access
switchport access vlan 2
switchport voice vlan 12
#### Core
int vlan 1
description Server VLAN
ip add 192.168.1.1 255.255.255.0
int vlan 2
description User VLAN
ip address 10.1.1.1 255.255.254.0
ip helper-address 192.168.1.100
int vlan 12
description voice vlan
ip addres 10.100.100.1 255.255.254.0
DHCP / DNS configured on Windows 2008 - 192.168.1.100
Voice Server - 192.168.1.55
ST
I'm far from being an expert but Cisco recommends the 2nd approach when possible or you could trunk if your switch doesn't regcognize auxiliary VLANs and put the data VLAN as the native VLAN.
As far as QoS goes here is what Cisco recommends: http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html
Regards.
Alain.
cadet alain
in #1: both VLANs are tagged and in #2 only the voice VLAN is tagged.
Regards.
Alain.
What is the best practise approach for voice traffic based on you EXPERT experience.  Also seeking your opinion on QOS approach for LAN and WAN Users on voice traffic .
Regards.
Alain.
