VPC nexus VLAN Routing
Ibrahim Jamil
Level 6
Level 6
Hi Experts
All clients in vlan 35 are configured with gateway 10.1.35.1. Make sure that outgoing traffic into this vlan is handled by gateway 10.1.35.2 without changing the clients’ configuration.
N7K-1 and N7K-2 in vpc domain 111 and the peer-link its configured on F1 module , also VLAan 45 and vlan 75 UP on the peer-link
N7K-1 ////  N7K-2
vpc domain 111
  peer-gateway
only peer-gateway seems wrong we need to exclude vlan 30 also as we run F1 module
pls be informed the chassis its M1 anf F1
i am following this
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/nexus-7000-f1-series-32-port-1-10-gigabit-ethernet-module/116740-config-vpc-l3-00.html
Thanks all
Will Kerr
I'm really confused by your question.  VPC is not a solution that is used to allow gateway masking.  Can you possibly provide some topology diagram here?
