VPC + SVI problem
magedis0383
We have the topology in Attachement. and we have problem with SVI and VPC
The configuration:
N5K1:
vpc domain 100
  peer-switch
  role priority 100
  system-priority 1024
  peer-keepalive destination 192.168.21.1
  peer-config-check-bypass
  delay restore 150
  peer-gateway
  auto-recovery
  ip arp synchronize
vlan 801
  name DEV_WAN
interface Vlan801
  description IP DEV
  no shutdown
  no ip redirects
interface Vlan1000
  no shutdown
  no ip redirects
  ip address 192.168.22.5/30
interface port-channel1000
  switchport mode trunk
  spanning-tree port type network
  spanning-tree guard loop
  vpc peer-link
interface port-channel401
  description LACP-SRV1
  speed 1000
  duplex full
  vpc 401
interface Ethernet1/1
  description "TRUNK VPC"
  no cdp enable
  spanning-tree bpdufilter enable
  channel-group 1000 mode active
interface Ethernet1/2
interface Ethernet1/5
  description SRV1_GB2
  speed 1000
  duplex full
  channel-group 401 mode active
interface Ethernet1/29
  description Uplink N5K3
N5K2:
vpc domain 100
  peer-switch
  role priority 110
  peer-keepalive destination 192.168.21.2
  delay restore 150
  peer-gateway
  auto-recovery
  ip arp synchronize
vlan 801
  name DEV_WAN
interface Vlan801
  no shutdown
  ip address 202.168.72.1/29
interface Vlan1000
  description VPC-N5K
  no shutdown
  no ip redirects
  ip address 192.168.22.6/30
  vpc peer-link
  speed 1000
  duplex full
  vpc 401
  description SRV1_GB4
  speed 1000
  duplex full
SRV1 IP: 202.168.72.2/29
When i plug the cable from SRV1 to N5K1 and N5K2 i can't ping SRV1 from ADM
when i unplug the cable from SRV1 to N5K2 i can't ping SRV1 from ADM
when i unplug the cable from SRV1 to N5K1 i CAN ping SRV1 from ADM
between N5K1, N5K2 and N5K3 we have OSPF
Thks !
2 Accepted Solutions
No ARP sync improves convergence times for L3 flows. When a vpc peer link fails and then recovers the vpc arp sync performs arp bulk sync over cfs from the vpc primary peer device to secondary peer device.
The Juniper world of virtual chassis can only be compared with VSS of Cisco, or stack-wise technology. These both are completely different the way they behave in comparison with vPC.
The loop prevention happens like this, a frame comes in over the vpc peer link destined to switch / route down a vpc member port. At that point once the frame traverses the vpc peer link, the receiving N5K will drop the frame, rule being, the vpc memeber port of the originating N5K from where the frame reached first should have forwarded the frame on to the host or down its own vpc member port since it was UP and functional.
Hope this helps
Bilal
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
What I was saying was if you peer N5K3 to N5K2 on a non vPC vlan you should be able to connect SRV1 with a vPC to both N5Ks.
Having N5K3 peer with N5K1 is not giving you redundancy because it is only connected to N5K2.
So it is more an illusion of redundancy.
From my last post you can see I am still trying to understand the exact loop it is seeing but Bilal knows this better than me so I'm hoping he can explain.
If you do connect N5K3 to both don't use a vPC otherwise you will see the very problems Bilal has mentioned.
Jon
48 Replies 48
Keith Nelson
I think you might need to allow VLAN 801 on the peer-link.
-Keith
he is already allowed
In fact when i make a traceroute from adm to srv1
the packet do:
ADM
N5K3
N5K2
N5K1
SRV1
because N5K1 "has" the vlan interface with the IP
That is not what your configuration says or perhaps I misunderstand what you mean by "has".
Jon
Yes sorry there is a mistake on the schema
N5K2 has the vlan interface with the IP
What vlan is the ADM in and where is the SVI for that vlan ?
Jon
In fact we have the problem with ADM or with any server which are outside our network.
For ADM the SVI is on N5K3, between N5K3 ans N5K1/2 we have OSPF too
What do traceroutes show when you have both connections plugged in on the server and when you are only connected to N5K2 ?
N5K3 is shown only connecting to N5K2, is that the way it is ie. there is no vPC from N5K3 to both N5K1 and 2 ?
When you did the traceroute from the ADM to the server you said it went via N5K1. What was the IP address of the hop on N5K1 ?
Jon
From srv1 with the both câble connected i can't ping the svi
from Adm i stop at n5k2
Between n5k3 and n5k2 no vpc
and from srv1 with the both câble connected i can ping the svi without problem evenif i unplug the câble from n5k2
Can you post a "sh vpc brief" ?
Jon
n5k01# sh vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 100
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 8
Peer Gateway                      : Enabled
Peer gateway excluded VLANs     : -
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
vPC Peer-link status
id   Port   Status Active vlans
1    Po1000 up     1-3,101-102,110,700-703,705,710,730,801,803,1000,3
                   001-3008,3400-3401
vPC status
id     Port        Status Consistency Reason                     Active vlans
1      Po1         up     success     success                    1-3,101-102
        ,110,700-70
        3,705,710,7
        30,801,803,
        1000,300....
401    Po401       down*  success     success                    -
(The cable is unplug)
n5K02# sh vpc brief
Legend:
vPC domain id                     : 100
vPC role                          : secondary
                   001-3008,3400-3401
vPC status
        ,110,700-70
        3,705,710,7
        30,801,803,
        1000,300....
401    Po401       up     success     success                    1-3,101-102
        ,110,700-70
        3,705,710,7
        30,801,803,
        1000,300....
The above two statements contradict each other ?
Also you said that from the ADM a traceroute gets to N5K1 in an earlier post and in this one you are saying it stops at N5K2 ?
Can you clarify exactly what the issue is ?
Jon
Erf sorry
from srv1  with the both cable connected or with only one connected i CAN ping the svi
from ADM1 with the both cable connect i CAN'T ping the SRV1
and from ADM1 a traceroute when the both cable is connected i stop at N5K2
whereas when there is only the cable connected to N5K2 the traceroute do:
ADM1
N5K3
N5K2
SRV1
when the cable is only connected to N5K1
ADM1
N5K3
N5K2
STOP
Does the N5K3 have a point to point OSPF neighborship with N5K2? Please describe to us how your ospf is configured.
Bilal
