Which Image should we need for the below model router 2951 to support 4 Byte ASN number ?
Senthil Kumar P
Hi All,
CISCO2951/K9Cisco 2951 w/3 GE 4 EHWIC 3 DSP 2 SM 256MB CF 512MB DRAM IPB
PWR-2921-51-ACCisco 2921/2951 AC Power Supply
CAB-ACSAAC Power Cord (South Africa) C13 BS 546 1.8m
HWIC-BLANKBlank faceplate for HWIC slot on Cisco ISR
ISR-CCP-EXPCisco Config Pro Express on Router Flash
MEM-2951-512MB-DEF512MB DRAM (1 512MB DIMM) for Cisco 2951 ISR (Default)
MEM-CF-256MB256MB Compact Flash for Cisco 1900 2900 3900 ISR
SM-S-BLANKRemovable faceplate for SM slot on Cisco 290039004400 ISR
SL-29-IPB-K9IP Base License  for Cisco 2901-2951
S2951UK9-15501TCisco 2951 IOS UNIVERSAL
EHWIC-1GE-SFP-CU
EHWIC 1 port dual mode SFP(100M/1G) or GE(10M/100M/1G)
Senthil Kumar P
Hi All,
Can someone suggest ?
a forum is no realtime-communication ... ;-)
For the ISR G1, it was supported from 12.4(24)T, so I would assume that your ISR G2 has this feature if you are running 15.x.
EDIT: The Feature-navigator says that it's supported starting with 15.1(2)T.
