VPC + SVI problem
magedis0383
We have the topology in Attachement. and we have problem with SVI and VPC
The configuration:
N5K1:
vpc domain 100
  peer-switch
  role priority 100
  system-priority 1024
  peer-keepalive destination 192.168.21.1
  peer-config-check-bypass
  delay restore 150
  peer-gateway
  auto-recovery
  ip arp synchronize
vlan 801
  name DEV_WAN
interface Vlan801
  description IP DEV
  no shutdown
  no ip redirects
interface Vlan1000
  no shutdown
  no ip redirects
  ip address 192.168.22.5/30
interface port-channel1000
  switchport mode trunk
  spanning-tree port type network
  spanning-tree guard loop
  vpc peer-link
interface port-channel401
  description LACP-SRV1
  speed 1000
  duplex full
  vpc 401
interface Ethernet1/1
  description "TRUNK VPC"
  no cdp enable
  spanning-tree bpdufilter enable
  channel-group 1000 mode active
interface Ethernet1/2
interface Ethernet1/5
  description SRV1_GB2
  speed 1000
  duplex full
  channel-group 401 mode active
interface Ethernet1/29
  description Uplink N5K3
N5K2:
vpc domain 100
  peer-switch
  role priority 110
  peer-keepalive destination 192.168.21.2
  delay restore 150
  peer-gateway
  auto-recovery
  ip arp synchronize
vlan 801
  name DEV_WAN
interface Vlan801
  no shutdown
  ip address 202.168.72.1/29
interface Vlan1000
  description VPC-N5K
  no shutdown
  no ip redirects
  ip address 192.168.22.6/30
  vpc peer-link
  speed 1000
  duplex full
  vpc 401
  description SRV1_GB4
  speed 1000
  duplex full
SRV1 IP: 202.168.72.2/29
When i plug the cable from SRV1 to N5K1 and N5K2 i can't ping SRV1 from ADM
when i unplug the cable from SRV1 to N5K2 i can't ping SRV1 from ADM
when i unplug the cable from SRV1 to N5K1 i CAN ping SRV1 from ADM
between N5K1, N5K2 and N5K3 we have OSPF
Thks !
48 Replies 48
No you can't because N5K3 would form OSPF peerings across the vPC peer link as well which could lead to dropped packets because of what Bilal described.
See diagram 2 in the link I posted because that is the exact scenario you are asking about.
Jon
So what is the best scenario in my case ?
It depends on what vlans are on N5K3. ?
If the vlans are not anywhere else ie. they are only on N5K3 then you can connect N5K3 to both N5K1 and N5K2 using L3 P2P links. This would mean N5K3 had peerings with both switches but no other indirect peerings.
Using a vPC to connect them up means you have allow the vlan across the vPC peer link and so indirect neighborships are formed.
I know you can define static neighborships in OSPF as opposed to using multicast so that may be a solution but I can't say as I have never done it.
Jon
I need vlan between N5K3 and N5K1/N5K2 so i can't do direct peering.
