VPDN or dialer interface
chamaraw07
hi guys
need some help on this , when i configure PPPoE should i configure vpdn or a dialer interface? what the difference of both ?
thanks
chamara
6 Replies 6
Hello Chamara,
VPDN is typically used when your client device connects to an access server. What is your setup ? Are you simply trying to connect to an ISP using PPPoE ? And what is your client device/platform (e.g. Cisco 887) ?
hi Georg
yes we are trying to connect to ISP using PPPoE , the device is a cisco ASA firewall
Hello Chamara,
with the ASA, use the VPDN setup. Do you need help with the configuration?
hi Georg
thanks , appreciate if you can send the config as well , also what the difference between VPDN and dialer interfaces , when should we use each? is it device specific ?
Chamara,
dialer interfaces are for routers, I don't even think you can configure those on a ASA. Either way, the link below has sample configs for the ASA as a PPPoE client (since I don't know which OS version you are running:
http://www.dslreports.com/faq/14232
