Config Filename
Hello
How can i store the config with the name of the hostname? I would store with cron the config with the hostname which shuld be inserted by command
so
 show run | redirect tftp://192.168.X.XX/  "Hostname"   .txt
Diana Karolina Rojas
Your question is confusing to me, what do you want to do?
The format of that command is correct, the general format is: tftp:[[//location]/directory]/filename
and example of configuration is:
kron policy-list Backup
cli show run | redirect tftp://X.X.X.X/hostname.cfg or .txt
exit
kron occurrence Backup in 3
policy-list Backup
You have to write the hostname in the filename of every device.
Hello
This is what i alredy have.
So i will make a backup of the router by including the hostname in the filname.
I create a kron and the command will automatic insert the hostname in the filname.
maybe the command would be
show run | redirect  tftp://192.168.1.X/$(hostname).txt
So you know what i will do?   the $(hostname)  will be the hostname from the router and will e stored in the filname.
I hope this is clear. ;)
