VPLS ASR 1004 device
pramod
How to configure VPLS on ASR 1004 device.Which version ASR support this functionality.
Please provide configuration doc (VPLS ASR)
Laurent Aubert
VPLS is not supported currently on the ASR1000 but should be in the future.
Laurent.
   Excuse me ! ASR 1004 can support VPLS now ?
Looking forward to your reply ,thanks!
Yes. It is supported now.
-Nagendra
Dear Nagendra,
    Thanks your reply !    I used  this devices to configure VPLS  ( 3750--7609 -----ASR 1004 --2950  ), but the VC status is down .I referenced the  official configuration  and asked my friends ,still couldn't find the reasons. It's the  issue of devices  compatibility ?
    If you have time ,can you help me Analysis the problem ?
Thank you very much !
7609:
mpls label protocol ldp
mpls ldp neighbor 10.10.10.102 targeted ldp
mpls ldp discovery hello holdtime 5
mpls ldp discovery targeted-hello accept
mpls ldp router-id Loopback0 force
l2 router-id 10.10.10.101
l2 vfi aaa manual
 vpn id 101
 neighbor 10.10.10.102 encapsulation mpls
interface Loopback0
 ip address 10.10.10.101 255.255.255.255
interface GigabitEthernet5/2  (to 3750)
 switchport
 switchport access vlan 101
 switchport mode access
 media-type rj45
 speed 100
interface GigabitEthernet6/2   (to ASR1004 )
 ip address 12.1.1.1 255.255.255.252
 media-type rj45
 mpls ip
interface Vlan101
 no ip address
 xconnect vfi aaa
router eigrp 90
 network 10.10.10.101 0.0.0.0
 network 12.1.1.0 0.0.0.3
ASR1004:
mpls ldp neighbor 10.10.10.101 targeted ldp
bridge-domain 101
l2 router-id 10.10.10.102
l2 vfi aaa manual
 vpn id 101
 bridge-domain 101
 neighbor 10.10.10.101 encapsulation mpls
interface Loopback0
 description test vpls
 ip address 10.10.10.102 255.255.255.255
interface GigabitEthernet0/0/0           (to 7609)
 ip address 12.1.1.2 255.255.255.252
 speed 1000
 no negotiation auto
 mpls ip
interface GigabitEthernet0/0/1      (to 2950 )
 no ip address
 speed 100
 no negotiation auto
 service instance 101 ethernet
  encapsulation dot1q 101
  bridge-domain 101
router eigrp 90
 network 10.10.10.102 0.0.0.0
CE configuration like this:  access mode
CE1:
interface FastEthernet1/0/1
end
interface Vlan101
 ip address 192.168.20.10 255.255.255.0
end
CE2 :
interface FastEthernetF0/1
end
interface Vlan101
 ip address 192.168.20.20 255.255.255.0
end
ASR1004#SHOW MPLs L2transport VC DETail
Local interface: VFI aaa vfi up
  Interworking type is Ethernet
  Destination address: 10.10.10.101, VC ID: 101, VC status: down
    Last error: Remote peer access circuit is down
    Output interface: Gi0/0/0, imposed label stack {17}
    Preferred path: not configured
    Default path: active
    Next hop: 12.1.1.1
  Create time: 22:24:49, last status change time: 00:00:33
    Last label FSM state change time: 21:17:13
  Signaling protocol: LDP, peer 10.10.10.101:0 up
    Targeted Hello: 10.10.10.102(LDP Id) -> 10.10.10.101, LDP is UP
7609#show mpls l2transport vc detail
  Destination address: 10.10.10.102, VC ID: 101, VC status: down
    Last error: MPLS dataplane reported a fault to the nexthop
    Output interface: none, imposed label stack {}
    Default path: no route
    No adjacency
  Create time: 1d12h, last status change time: 21:18:20
    Last label FSM state change time: 00:00:40
  Signaling protocol: LDP, peer 10.10.10.102:0 up
    Targeted Hello: 10.10.10.101(LDP Id) -> 10.10.10.102, LDP is UP
