VPLS autodiscovery between cisco and juniper
bangladesh
Hi Guys,
This is my first post here , so excuse me if i am posting this in the wrong section.
I am trying to setup up VPLS between a cisco 7604 and a juniper MX router. I work for a big enterprise in Bangladesh and i need to have this up and running soon :)
I configured auto vpls discovery and it doesn't seem to be working. VPLS is still down.
IGP is IS-IS and LDP neighbor is up and running.  The 2 boxes are connected via a port channel.(2x1gig)
Can someone please have a look at the below config:
sh run ( unnecessary output has been removed)
no ip source-route
mpls ldp graceful-restart
mpls label protocol ldp
mls flow ip interface-full
no mls flow ipv6
mls cef error action reset
bridge-domain 1406
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
vlan 1406
pseudowire-class mpls
 encapsulation mpls
 no control-word
l2 router-id 172.18.0.46
l2 vfi vpls1 autodiscovery
 vpn id 1406
interface Loopback0
 ip address 172.18.0.46 255.255.255.255
 ip router isis
interface Port-channel9
 ip address 172.18.2.18 255.255.255.252
 ip router isis
 mpls ip
interface GigabitEthernet1/1
 no ip address
 channel-group 9 mode active
interface GigabitEthernet1/2
 no ip address
interface GigabitEthernet2/48
 switchport
 switchport access vlan 1406
 switchport mode access
interface Vlan1406
 ip address 172.30.16.133 255.255.255.252
 xconnect vfi vpls1
router isis
 net 49.0001.1720.1800.0046.00
 is-type level-2-only
 metric-style wide
 log-adjacency-changes
router bgp 66xxx
 bgp router-id 172.18.0.46
 no bgp default ipv4-unicast
 bgp log-neighbor-changes
 neighbor 172.18.0.3 remote-as 66xxx
 neighbor 172.18.0.3 update-source Loopback0
 neighbor 172.18.0.3 timers 30 90
 address-family ipv4
  no synchronization
  no auto-summary
 exit-address-family
 address-family vpnv4
  neighbor 172.18.0.3 activate
  neighbor 172.18.0.3 send-community both
 exit-address-family
 address-family l2vpn vpls
  neighbor 172.18.0.3 prefix-length-size 2
 exit-address-family
ip bgp-community new-format
mpls ldp router-id Loopback0 force
7604# sh interfaces vlan 1406
Vlan1406 is up, line protocol is up
7604#show xconnect all
Legend:    XC ST=Xconnect State  S1=Segment1 State  S2=Segment2 State
  UP=Up       DN=Down            AD=Admin Down      IA=Inactive
  SB=Standby  HS=Hot Standby     RV=Recovering      NH=No Hardware
XC ST  Segment 1                         S1 Segment 2                         S2
UP     ac   Vl1406:1406(Eth VLAN)        UP vfi  vpls1                        UP
7604#show vfi
Legend: RT=Route-target, S=Split-horizon, Y=Yes, N=No
VFI name: vpls1, state: up, type: multipoint
  VPN ID: 1406, VPLS-ID: 30999:1406
  RD: 30999:1406, RT: 30999:1406
  Local attachment circuits:
    Vlan1406
  Neighbors connected via pseudowires:
  Peer Address     VC ID        Discovered Router ID    S
show mpls ldp neighbor
    Peer LDP Ident: 172.18.0.3:0; Local LDP Ident 172.18.0.46:0
        TCP connection: 172.18.0.3.646 - 172.18.0.46.17356
        State: Oper; Msgs sent/rcvd: 983/794; Downstream
        Up time: 02:07:05
        LDP discovery sources:
          Port-channel9, Src IP addr: 172.18.2.17
        Addresses bound to peer LDP Ident:
           172.18.0.3      x.x.x.x
If you look at the output there, the signaling is LDP. Also, the linecard being used is ES+. Thats the reason why its working for them.
Hope this clarifies.
--Vinit
27 Replies 27
bangladesh
which debug could i use to troubleshoot this issue?
Could you please refer to the below post to configure VPLS audo-discovery:
http://blog.codergenie.com/blog/post/2013/01/01/BGP-based-VPLS-Autodiscovery.aspx
Please let know what linecards are you running on Core and the CE facing. Please share the show module.
Vinit
--Vinit
Hi vinit,
i am using DESCR: "RSP720-3C-GE 2 ports Route Switch Processor 720 Rev. 5.12
Thanks for the link. I will check it.
below is a show inventory:
NAME: "CISCO7604", DESCR: "Cisco Systems Cisco 7600 4-slot Chassis System"
NAME: "CLK-7600 1", DESCR: "OSR-7600 Clock FRU 1"
NAME: "CLK-7600 2", DESCR: "OSR-7600 Clock FRU 2"
NAME: "module 1", DESCR: "RSP720-3C-GE 2 ports Route Switch Processor 720 Rev. 5.12"
NAME: "msfc sub-module of 1", DESCR: "7600-MSFC4 C7600 MSFC4 Daughterboard Rev. 1.6"
NAME: "switching engine sub-module of 1", DESCR: "7600-PFC3C Policy Feature Card 3 Rev. 1.2"
NAME: "module 2", DESCR: "WS-X6748-GE-TX CEF720 48 port 10/100/1000mb Ethernet Rev. 4.1"
NAME: "switching engine sub-module of 2", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.1"
Please find below requested output:
7604#sh module
Mod Ports Card Type                              Model              Serial No.
  1    2  Route Switch Processor 720 (Active)    RSP720-3C-GE
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  68ef.bdd3.69f4 to 68ef.bdd3.69f7   5.12  12.2(33r)SRD 12.2(33)SRE4 Ok
  2  0007.7d04.0000 to 0007.7d04.002f   4.1   12.2(18r)S1  12.2(33)SRE4 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Policy Feature Card 3       7600-PFC3C         JAE1451013O  1.2    Ok
  1  C7600 MSFC4 Daughterboard   7600-MSFC4         JAE144906UB  1.6    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1535NSN9  4.1    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
Hello
67XX cards are lan cards and might not have support for EVC (Service instance). Its supported on cards like ES20 or ES+.
I see your xconnect is up. Are you able to pass traffic across it?
Can you share the output of a pseudowire ping from PE to PE and please share the below output:
- show mpls l2 vc <vcid> det
Vinit
--Vinit
7604#show mpls l2 vc 1406 detail
7604#
vc seems to be down. Same is down at juniper end too. Is there some specific features that should be configured? are you used to junos ?
Local intf     Local circuit              Dest address    VC ID      Status
7604#
Sorry, I am not used to Junos. The only other thing i can ask you to try try ES20 or ES+ linecard as your Core link rather than having RSP or any LAN card as Core.
If you are using xconnect under SVI, then i think you should use one of the WAN cards like SIP-400, SIP-600 or ES20/ES+ cards as your Core link. This applies for EoMPLS, so possibly shud be applicable for VPLS.
Can you try your Core facing linecard as any of the above WAN cards.
http://www.cisco.com/c/en/us/td/docs/ios/mpls/configuration/guide/15_0s/mp_15_0s_book/mp_vpls_auto_bgp.pdf
Vinit
--Vinit
Thanks for the input.
Unfortunately we don't have other linecards.
Will static VPLS work?
Hi the xconnect is now up. the juniper had to be configured with multihoming vpls option.
M7604#sh xconnect all
UP     vfi  vpls1                        UP mpls 172.18.0.3:1406              UP
M7604#sh vfi
    Vlan1406
  172.18.0.3       1406         172.18.0.3              Y
Setup:
7604---MX--Test Switch
The 7604 has an ip address assigned to the interface vlan 1406.
I also assigned an IP to the interface vlan 1406 on the test switch. Unfortunately i am not able to ping both ends.
any ideas?
Are you able to perform a psedowire ping between 7600 and Juniper.
Also, If you perform the ping, in the show mpls l2 vc <vcid> det output, do you see the packet counters incrementing? If yes, are you seeing both send and receive counters incrementing?
--Vinit
can do give me the correct syntax for pseudowire ping?
MPLS_7604_ASN#ping mpls pseudowire 172.30.16.134 1406
% Pseudowire Target Not Supported
From below output i can see : TLV not supported on remote. Is this important for the VPLS session? because i enabled same on junos and the status remained the same.
The sent counters are zero.
MPLS_7604_ASN#show mpls l2 vc 1406 detail
Local interface: VFI vpls1 VFI up
  Interworking type is Ethernet
  Destination address: 172.18.0.3, VC ID: 1406, VC status: up
    Output interface: Po9, imposed label stack {458767}
    Preferred path: not configured
    Default path: active
    Next hop: 172.18.2.17
  Create time: 08:07:54, last status change time: 00:10:34
  Signaling protocol: LDP, peer 172.18.0.3:0 up
    Targeted Hello: 172.18.0.46(LDP Id) -> 172.18.0.3, LDP is UP
    Status TLV support (local/remote)   : enabled/not supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: Not sent
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 165, remote 458767
    AGI: type 1, len 8, 000A 7917 0000 057E
    Local AII: type 1, len 4, AC12 002E (172.18.0.46)
    Remote AII: type 1, len 4, AC12 0003 (172.18.0.3)
    Group ID: local n/a, remote n/a
    MTU: local 1500, remote 1500
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  VC statistics:
    transit packet totals: receive 1648, send 0
    transit byte totals:   receive 98820, send 0
    transit packet drops:  receive 0, seq error 0, send 0
Thanks for the output. The syntax for psedowire ping is below:
ping mpls pseudowire <remote_PE_loopback> <vcid>
Also, from the above output, i see that the send counters is not incrementing. Like i said before, this is possible due to the LC limitation. I might have to further research a bit on it.
Vinit
--Vinit
Thanks. i tried the command
Don't know where to go from here. We've got thousands of VPLS sessions running on our juniper boxes and this cisco box is bugging me.
Thanks for your help. I really appreciate it :)
Your destination is wrong. it should be 172.18.0.3.
Can you try with this.
--Vinit
