VPLS autodiscovery between cisco and juniper
bangladesh
Hi Guys,
This is my first post here , so excuse me if i am posting this in the wrong section.
I am trying to setup up VPLS between a cisco 7604 and a juniper MX router. I work for a big enterprise in Bangladesh and i need to have this up and running soon :)
I configured auto vpls discovery and it doesn't seem to be working. VPLS is still down.
IGP is IS-IS and LDP neighbor is up and running.  The 2 boxes are connected via a port channel.(2x1gig)
Can someone please have a look at the below config:
sh run ( unnecessary output has been removed)
no ip source-route
mpls ldp graceful-restart
mpls label protocol ldp
mls flow ip interface-full
no mls flow ipv6
mls cef error action reset
bridge-domain 1406
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
vlan 1406
pseudowire-class mpls
 encapsulation mpls
 no control-word
l2 router-id 172.18.0.46
l2 vfi vpls1 autodiscovery
 vpn id 1406
interface Loopback0
 ip address 172.18.0.46 255.255.255.255
 ip router isis
interface Port-channel9
 ip address 172.18.2.18 255.255.255.252
 ip router isis
 mpls ip
interface GigabitEthernet1/1
 no ip address
 channel-group 9 mode active
interface GigabitEthernet1/2
 no ip address
interface GigabitEthernet2/48
 switchport
 switchport access vlan 1406
 switchport mode access
interface Vlan1406
 ip address 172.30.16.133 255.255.255.252
 xconnect vfi vpls1
router isis
 net 49.0001.1720.1800.0046.00
 is-type level-2-only
 metric-style wide
 log-adjacency-changes
router bgp 66xxx
 bgp router-id 172.18.0.46
 no bgp default ipv4-unicast
 bgp log-neighbor-changes
 neighbor 172.18.0.3 remote-as 66xxx
 neighbor 172.18.0.3 update-source Loopback0
 neighbor 172.18.0.3 timers 30 90
 address-family ipv4
  no synchronization
  no auto-summary
 exit-address-family
 address-family vpnv4
  neighbor 172.18.0.3 activate
  neighbor 172.18.0.3 send-community both
 exit-address-family
 address-family l2vpn vpls
  neighbor 172.18.0.3 prefix-length-size 2
 exit-address-family
ip bgp-community new-format
mpls ldp router-id Loopback0 force
7604# sh interfaces vlan 1406
Vlan1406 is up, line protocol is up
7604#show xconnect all
Legend:    XC ST=Xconnect State  S1=Segment1 State  S2=Segment2 State
  UP=Up       DN=Down            AD=Admin Down      IA=Inactive
  SB=Standby  HS=Hot Standby     RV=Recovering      NH=No Hardware
XC ST  Segment 1                         S1 Segment 2                         S2
UP     ac   Vl1406:1406(Eth VLAN)        UP vfi  vpls1                        UP
7604#show vfi
Legend: RT=Route-target, S=Split-horizon, Y=Yes, N=No
VFI name: vpls1, state: up, type: multipoint
  VPN ID: 1406, VPLS-ID: 30999:1406
  RD: 30999:1406, RT: 30999:1406
  Local attachment circuits:
    Vlan1406
  Neighbors connected via pseudowires:
  Peer Address     VC ID        Discovered Router ID    S
show mpls ldp neighbor
    Peer LDP Ident: 172.18.0.3:0; Local LDP Ident 172.18.0.46:0
        TCP connection: 172.18.0.3.646 - 172.18.0.46.17356
        State: Oper; Msgs sent/rcvd: 983/794; Downstream
        Up time: 02:07:05
        LDP discovery sources:
          Port-channel9, Src IP addr: 172.18.2.17
        Addresses bound to peer LDP Ident:
           172.18.0.3      x.x.x.x
27 Replies 27
man , you're a legend :)
the ping works.
7604#ping mpls pseudowire 172.18.0.3 1406
%Total number of MS-PW segments is less than segment number; Adjusting the segment number to 1
Sending 5, 100-byte MPLS Echos to 172.18.0.3,
     timeout is 2 seconds, send interval is 0 msec:
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
  'L' - labeled output interface, 'B' - unlabeled output interface,
  'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
  'M' - malformed request, 'm' - unsupported tlvs, 'N' - no label entry,
  'P' - no rx intf label prot, 'p' - premature termination of LSP,
  'R' - transit router, 'I' - unknown upstream index,
  'X' - unknown return code, 'x' - return code 0
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
7604#
ok.. so now can you share the show mpls l2 vc <vcid> det output again to see if the send counters incremented.
I still think my suspect is correct on the support on VPLS with Core facing card as RSP.
Let me see if i can setup something at my end to check this out.
Vinit
--Vinit
nope....still zero
MPLS_7604_ASN#sh mpls l2 vc 1406 detail
Local interface: VFI vpls1 VFI up
  Interworking type is Ethernet
  Destination address: 172.18.0.3, VC ID: 1406, VC status: up
    Output interface: Po9, imposed label stack {458767}
    Preferred path: not configured
    Default path: active
    Next hop: 172.18.2.17
  Create time: 11:55:24, last status change time: 03:58:03
  Signaling protocol: LDP, peer 172.18.0.3:0 up
    Targeted Hello: 172.18.0.46(LDP Id) -> 172.18.0.3, LDP is UP
    Status TLV support (local/remote)   : enabled/not supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: Not sent
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 165, remote 458767
    AGI: type 1, len 8, 000A 7917 0000 057E
    Local AII: type 1, len 4, AC12 002E (172.18.0.46)
    Remote AII: type 1, len 4, AC12 0003 (172.18.0.3)
    Group ID: local n/a, remote n/a
    MTU: local 1500, remote 1500
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  VC statistics:
    transit packet totals: receive 1648, send 0
    transit byte totals:   receive 98820, send 0
    transit packet drops:  receive 0, seq error 0, send 0
In the output above , it says that the signalling protocol is LDP. Shouldn't it be BGP according to the config?
Thanks for your help
7600 doesn't support BGP signaling. It only supports LDP signaling. VPLS AD can happen using BGP but signaling will be LDP.
--Vinit
Can you run the below command on SP of RSP720.
remote login switch
show platform atom ether-vc vlan <> all
I was researching a bit on this and found that RSP cannot be a core facing interface for VPLS. It has to be one of the linecards that i mentioned before.
Hope this answers why you are facing the problem.
Vinit
--Vinit
Command does not seem to be supported:
7604#show platform  atom ?
% Unrecognized command
7604#show platform  ?
  bridge        Distributed/Hardware-based bridging information
  buffers       Show buffer allocation
  cfm           Show CFM Commands
  copp          CWAN Control Plane Policing
  dma           Show DMA channel information
  eeprom        Show CPU eeprom
  eobc          Statistics Information for eobc between RP/SP and Linecards
  fault         Show fault data
  fifo          Statistics for eobc-fifo between RP and SP
  hardware      Show platform hardware information
  ibc           Statistics for IBC
  interrupts    Show m8500 interrupt counters
  isg           CWAN iEdge RP
  ivrf status    platform ivrf status
  lowq          Display X40g low queue information
  ltl-mgr       Display CWAN LTL manager info
  mplsomgre     CWAN Multipoint GRE RP
  mtp           Mac Tunneling Protocol info
  netint        Show platform net interrupt information
  redundancy    Display bias and CWAN platform redundancy
  software      Show platform software information
  stats         Display CWAN statistics
  supervisor    Show supervisor info
  tech-support  Show system information for Tech-Support
  tlb           Show processor TLB registers
  vfi           Display CWAN VFI commands
  vlans         Display hidden VLAN to WAN interface mapping
  |             Output modifiers
That kind of answers. This command is used to check the hardware programming for the vpls on core facing LC.
Thus now, the only solution, would be to use ES20 or ES+ linecards if possible or some other router that supports this feature.
Please let me know if you have any further questions.
Vinit
PS: Please mark the question as answered if all your queries have been answered
--Vinit
Hi thanks for the input. But in the example you provided (http://blog.codergenie.com/blog/post/2013/01/01/BGP-based-VPLS-Autodiscovery.aspx) , the guy is using the same linecard as me for vpls autodiscovery via bgp signalling.
Could it be an IOS issue?
If you look at the output there, the signaling is LDP. Also, the linecard being used is ES+. Thats the reason why its working for them.
Hope this clarifies.
--Vinit
Hi ,
in the case scenarion in the link , the created a service instance. I currently don't have the same options.( encapsulation dot1q,rewrite ingress tag pop 1 symmetric,l2protocol forward, etc...)
7604(config)#interface GigabitEthernet2/47
7604(config-if)#service instance 1406 ethernet
7604(config-if-srv)#?
Ethernet EFP configuration commands:
  default   Set a command to its defaults
  ethernet  Configure ether lmi parameters
  exit      Exit from ETHER EFP configuration mode
  no        Negate a command or set its defaults
any ideas?
bangladesh
has anyone ever make this kind of setup between juniper and cisco?
bangladesh
MPLS_7604_ASN#sh version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE4, RELEASE SOFTWARE (fc2)
for your info.
thanks
