VPLS on Trunk interface. Move one VLAN into VPLS instance?
I have a trunk coming into a CSR1000V. This trunk carries lots of VLANs and each VLAN has it's down routed subnet.
I want to be able to put a specific VLAN on this trunk into a customers VPLS. Is this possible?
I can move the interface as a whole into a VPLS but I can't get just the VLAN in without it affecting the whole trunk.
The relevant part of example config is below:
l2vpn vfi context TEST-VPLS-CUST1
vpn id 101
mtu 1500
autodiscovery bgp signaling bgp
ve id 4
ve range 100
rd 6060:6060
route-target export 6060:6060
route-target import 6060:6060
bridge-domain 101
member GigabitEthernet2 service-instance 1
member vfi TEST-VPLS-CUST1
interface GigabitEthernet2
no ip address
negotiation auto
service instance 1 ethernet
encapsulation dot1q 10
rewrite ingress tag pop 1 symmetric
storm-control broadcast cir 50000
storm-control multicast cir 8000
Gig2 is the port which is carrying the multiple VLANs and I just want to move VLAN10 into the VPLS instance. If I change the interface to a standard access port and change the encapsulation dot1q 10 to encapsulation default then it works fine but as mentioned this moves the whole interface into the VPLS which is not what I want.
I am using route-reflectors for this but it's not really relevant as I'm just testing on the one PE router at the moment.
Any help MUCH appreciated :)
0 Replies 0
