VPN 2 ISP's Main Office - 1 ISP BranchOffice Gateway Problem
aceclub123
We currently have an exchange server located at our head office IP address 192.168.0.10 with a Cisco Firewall/modem at gateway address 192.168.0.254. Connecting to the Internet picking up exchange mail and web browsing for the PC’s attached to Head office
We recently installed an additional Cisco VPN Router at address 192.168.0.253 (head Office) with its own isp connection to allow the remote office to connect ot our server and hopefully access exchange mail, accounting software etc.
A VPN Tunnel has been setup between Head office and the remote office; the tunnel stays connected and works fine. We can ping or connect to any computer at the remote office from the head office.
The problem is that we can’t ping or connect to any computers at the head office from the remote site that don’t the have the Cisco’s VPN Router’s IP address of (192.168.0.253)
The IP range at the Remote Office is 192.168.12.1-254 Gateway Address is 192.168.12.1
We can ping any Computer at head Office from the remote Office if the gateway address in the PC at the Head Office is changed to 192.168.0.253
Is there any way to translate IP address’s to allow access to Servers/printers at the Head Office from the Remote Office?
Remote Office IP Range
192.168.12.1   - 192.168.12.254
DNS Server (Windows 2008 Standard Server) 192.168.12.20
Gateway Ip 192.168.1.1
Head Office IP Range
192.168.0.1 – 192.168.0.254
DNS Server (Windows 2003 Standard Server) 192.168.0.254
Gateway Ip 192.168.0.10
Other Severs I need to get access to Head Office from the Remote Office
192.168.0.10             Exchange/active directory server
192.168.0.20             Aristocrat Database Server
192.168.0.4              Document Server
Routers – Cisco 8-Port VPN Routers Model No RV082
5 Replies 5
Marwan ALshawi
it seesm to be that you have issues with routing the traffic
if you can post the config of both head office routers and the remote office router config too
mask the public ips like x.x.x.10 for example
and remove any username and passowrd before posting it here
Please find ip address info as follows if you need further info pls don’t hesitate to ask
Thank you for you help
Head Office Main Internet Connection
Cisco Router 192.168.0.254
Head Office VPN Connection to Remote Office
Gateway Ip 192.168.0.253 - Cisco VPN Router Model No RV082
Other Severs I need to get access at Head Office from the Remote/branch Office
Remote Office
IP Range 192.168.12.1   - 192.168.12.254
192.168.12.20 DNS Server (Windows 2008 Standard Server)
Gateway Ip 192.168.1.1 - Cisco VPN Router Model No RV082
as i mentioned if you can attach the configurations of the routers will be helpful for people to help you
as it could be VPN ACL, or routing issue for example
NO DHCP Servers turned on in any Modems, Router or Firewalls
Modem Cisco 800 Series
Cisco Firewall Model – ASA 5510 Series
IP Address 192.168.0.254
Subnet 255.255.255.0
Secondary Internet VPN Connection
Head office can access all PC’s at the branch office, Branch office can only access Pc’s/Servers at head office if they have the secondary Internets connection gateway applied
Head Office - Network Setup
Linksys VPN Router RVo82
VPN Connection
Branch Office - Network Setup
VPN Connection
Remote Office
You've got a routing issue at the head office.
Basically, you have two different routers, but only one default route - so, since you don't have an entry for the network at the remote end, the traffic is sent to the default gateway - which doesn't know where to send the traffic, so drops it off.
You can do one of two things.
1) Connect the two routers to the same layer 2 domain (which it seems you may have already), and put a static route into the device at 192.168.0.254 basically saying "anything for network 192.168.12.0/24, send via 192.168.0.253" - not sure of the exact format for this because I've not worked with these apparent Linksys devices before, but on an IOS router you would do something like
ip route 192.168.12.0 255.255.255.0 192.168.0.253
on the device at 192.168.0.254
2) Put a static route for the 192.168.12.0/24 network into every device/PC/server on the 192.168.0.0 network - in a windows machine it goes something like this
route add -p 192.168.12.0 mask 255.255.255.0 192.168.0.253
Option 1 is easier and has the benefot of only needing to be done on one device, but may lead to issues with redirects or traffic load levels on your main router.
Hope this helps.
Cheers.
