VPN - Dynamic IP
anthony.dyne
I have Cisco 877 routers, with ethernet (LAN) and ADSL (external) interfaces. The ADSL interface gets dynamic IP.
Is Site to Site VPN  with Dynamic IP and Internet Browsing Possible on the Same Router.
Anthony
Lei Tian
Hi Anthony,
When you define the ipsec peer, it can be configured either in IP or hostname, so if you can get hostname from ddns, I think it should work too.
Lei Tian
Can I get help with Demo config for VPN with Dynamic IP
thanks
Anthony
Check the link below, its about EZVPN (EasyVPN):
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/ezvpn.html
When you have single and/or dynamic remote ip's, this is the setup for you!
regards,
Leo
Hi Anthony,
I was not able to find a config example from cco, but I found an old post in netpro. Hope that helps.
https://supportforums.cisco.com/thread/343363
Lei Tian
