VPN Help
Adrian Jones
Hi All,
Can anyone check out my config and advise where my VPN Config is going wrong. There are two configs required. A Site to Site and a PC to Site.
I am testing the PC to site using VPN Client. If I have no username and password configured in the client I get the challenge for username and password but using my local log-in or the specified username and password does not work.
Essentially, as well as the site to site VPN I need two seperate logins under different username/passwords - listed here as Norsonic and Campbell Associates.
Config attached.
Adrian
16 Replies 16
Hi John,
That fixed it, it's working. I had reviewed the logs and saw the Pool error and was going to try that this evening. It's in, working and I've learnt plenty.
Thanks for all your help. You're a star.
Best Regards
Adrian
Glad to hear it, and thanks for letting us know :-)
John
HTH, John *** Please rate all useful posts ***
