02-14-2019 05:37 AM
Hello Experts,
@Richard Burts @Peter Paluch @Joseph W. Doherty @Julio E. Moisa @paul driver
I have question, We have four sites connected with each other through MPLS circuit. We are advertising our subnets by using ospf and I want to use DMVPN as secondary way to accomplish that. I have some doubts :
1. When I make tunnels thorough internet and run other ospf process to advertise. How i will manipulate parameters so that ospf with MPLS will be primary ?
2. Also when MPLS brokes it will automatically start commuting with DMVPN but when MPLS gets back it should start using MPLS again by itself ?
Please mention all possible ways ? Also mention other ways for redundancy for site to site connection ?
02-14-2019 06:23 AM
02-14-2019 07:02 AM
You can use the "default-information originate" command with a higher metric on the DMVPN tunnel to make it the secondary circuit.
Cheers
Mikey
02-14-2019 11:43 AM
If we knew a bit more about the environment of the original poster we might be able to give better advice. For example does each site form OSPF neighbor relationship with each of the other 3 sites? Or is there a HQ central site and other sites are neighbors with it but not with each other? Also when you run OSPF on your router are you forming neighbor relationship with the Provider Edge Router or neighbor relationship with a Customer router at the other site?
But if you have OSPF running successfully for MPLS I believe that it should not be too difficult to run OSPF for DMVPN and to make MPLS routes preferred. The original post seems to suggest running 2 OSPF processes. I am not sure there is much to be gained from 2 processes. I believe that Joseph is pointing in the right direction. Run OSPF on interfaces for MPLS and for DMVPN and assign OSPF cost on interfaces for DMVPN that is higher than cost on MPLS interfaces. That should achieve automatic failover and automatic failback.
The suggestion about default information originate shows creative thinking. But unfortunately it would not be much of a solution. But the question in this post is not so much about what default route to use but is more about how to answer questions like "where is subnet 172.16.26.0 (which site has this subnet) and which interface do I use to get there" than it is about which default route to use.
Rick
02-15-2019 06:42 AM
02-16-2019 07:13 AM
Joseph
Here is the line in the original post that I understand to indicate thinking about a second OSPF process:
I am glad that we agree that a second OSPF process would not be helpful.
Rick
02-17-2019 07:05 AM
