05-15-2006 02:00 AM - edited 03-03-2019 12:41 PM
Hi ,
I want to about the Vpn ip sec config on cisco 7207 VXR,
i need to basic steps for it.
Thank
05-15-2006 02:59 AM
Are you trying to go for RAVPN setup for your remote clients to get connected to your local lan using VPN Clients or is it normal IPSEC peers having vpn connectivity with your 7206 (location) ?
do refer this link for all kinda vpn config scenarios..
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
regds
05-15-2006 03:26 AM
hi
Thanks for the reply,
U want to use IP sec with EBGP ,, can i use it.with BGP ????
05-15-2006 03:29 AM
hi
