VPN IPSEC NOT WORKING
Hi good day!
I am having trouble connecting to our client's vpn after changing their public ip address. I've already created a new configuration for it and it is down as stated below.
Interface: FastEthernet0/0.32
Profile: ISAKMP-5J
Session status: DOWN-NEGOTIATING
Peer: 120.89.33.83 port 500 fvrf: (none) ivrf: (none)
Desc: (none)
Phase1_id: (none)
IKEv1 SA: local 10.8.32.3/500 remote 120.89.33.83/500 Inactive
Capabilities:(none) connid:0 lifetime:0
IPSEC FLOW: permit ip 192.168.50.0/255.255.255.0 149.122.30.0/255.255.255.0
Active SAs: 0, origin: crypto map
Inbound: #pkts dec'ed 151288 drop 28 life (KB/Sec) 0/0
Outbound: #pkts enc'ed 145786 drop 1503 life (KB/Sec) 0/0
R-IPSEC-1#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
120.89.33.83 10.8.32.3 MM_NO_STATE 0 ACTIVE
14 Replies 14
Philip D'Ath
Have you removed the old configuration (which you will need to do)?
Can you attach your current config?
Thank you replying. Oh I see so I need to removed the old configuration? But I already replaced the old one with the new config. The one that is having a problem is the isakmp profile ISAKMP-5J
hostname R-IPSEC-1
boot-start-marker
boot-end-marker
aaa new-model
aaa group server radius RADIUS-SERVERS
server name HTC-DC
ip radius source-interface FastEthernet0/0.8
load-balance method least-outstanding
aaa authentication login CONSOLE local group RADIUS-SERVERS
aaa authentication login RADIUS-ONLY group RADIUS-SERVERS
aaa authorization console
aaa authorization exec RADIUS-ONLY group RADIUS-SERVERS
aaa authorization exec CONSOLE local group RADIUS-SERVERS
aaa authorization network RA-VPN local
aaa session-id common
clock timezone GMT 8 0
dot11 syslog
no ip source-route
ip cef
ip domain lookup source-interface FastEthernet0/0.8
ip domain name helicon.local
ip name-server 172.30.100.2
ip name-server 172.30.100.3
login on-failure log
login on-success log
password encryption aes
license udi pid CISCO2811 sn FHK1006F10D
username helicon secret 4 nys/BA3iG8I/Is0oq4jW6gIWVLnfuCMctEOxTbOlzOM
redundancy
ip ssh time-out 30
ip ssh version 2
crypto keyring ISAKMP-5J-KEY
pre-shared-key address 120.89.33.83 key 6 D\NMdfOORChUMcWGOWIeVaIS]TaC]S^[OG\]YTCL\aAAB
crypto keyring ISAKMP-CMAN-KEY
pre-shared-key address 125.212.53.254 key 6 UYQC`IUfe^UXX]FVeOPHZReiIb^^ibIIcLHSEgcNTaAAB
crypto keyring ISAKMP-TR-KEY
pre-shared-key address 202.172.249.64 key 6 fbERf[FUQBh]AJD]eMaNYBgP`dFAFZf_GZCdNXTAAB
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
lifetime 28800
crypto isakmp policy 20
encr 3des
group 2
crypto isakmp policy 30
encr 3des
group 2
lifetime 28800
crypto isakmp client configuration group RA-VPN-HELICON
key 6 D`JGafHZgYSbWZQH`MO]VcZMBFV[afYV[eX\Cih\YLAAB
dns 172.30.100.3
domain helicon.local
pool RA-VPN
max-users 64
max-logins 1
crypto isakmp profile ISAKMP-5J
self-identity user-fqdn TSST
match identity user-fqdn TSST
keepalive 10 retry 5
crypto isakmp profile ISAKMP-TR
match identity address 202.172.249.64 255.255.255.255
crypto isakmp profile RA-VPN-HELICON
match identity group RA-VPN-HELICON
client authentication list RADIUS-ONLY
isakmp authorization list RA-VPN
client configuration address respond
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map DYNAMIC-IPSEC-PROPOSALS 10
set transform-set 3DES-SHA
set isakmp-profile RA-VPN-HELICON
reverse-route
qos pre-classify
crypto map IPSEC-PROPOSALS 10 ipsec-isakmp dynamic DYNAMIC-IPSEC-PROPOSALS
crypto map IPSEC-PROPOSALS 20 ipsec-isakmp
set peer 120.89.33.83
set pfs group2
set isakmp-profile ISAKMP-5J
match address IPSEC-5J
reverse-route static
crypto map IPSEC-PROPOSALS 40 ipsec-isakmp
set peer 202.172.249.64
set pfs group2
set isakmp-profile ISAKMP-TR
match address IPSEC-TR
interface Loopback0
ip address 192.168.211.1 255.255.255.255
ip nat inside
ip virtual-reassembly in
no ip address
duplex auto
speed auto
encapsulation dot1Q 8
ip address 10.8.8.4 255.255.255.0
interface FastEthernet0/0.32
encapsulation dot1Q 32
ip address 10.8.32.3 255.255.255.0
ip nat outside
ip policy route-map RA-VPN-IPSEC
ip ospf cost 200
ip ospf dead-interval 3
ip ospf hello-interval 1
interface FastEthernet0/1
ip address 10.8.9.6 255.255.255.252
ip nat inside
ip ospf 1 area 0
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
router ospf 1
router-id 10.8.8.4
auto-cost reference-bandwidth 1000
summary-address 192.168.211.0 255.255.255.0
redistribute static subnets route-map STATIC-TO-OSPF
passive-interface default
no passive-interface FastEthernet0/1
ip local policy route-map LOCAL-POLICY-ROUTING
ip local pool RA-VPN 192.168.211.2 192.168.211.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool NAT-IPSEC-5J 192.168.50.1 192.168.50.254 netmask 255.255.255.0
ip nat pool NAT-IPSEC-CMAN 192.168.231.1 192.168.231.254 netmask 255.255.255.0
ip nat pool NAT-IPSEC-TR 10.223.103.1 10.223.103.254 netmask 255.255.255.0
ip nat inside source list NAT-IPSEC-5J pool NAT-IPSEC-5J overload
ip nat inside source list NAT-IPSEC-CMAN pool NAT-IPSEC-CMAN overload
ip nat inside source list NAT-IPSEC-TR pool NAT-IPSEC-TR overload
ip route 0.0.0.0 0.0.0.0 10.8.32.1
ip access-list standard REMOTE-ADMIN
permit 172.30.102.0 0.0.0.255
ip access-list standard STATIC-TO-OSPF
deny 0.0.0.0
permit any
ip access-list extended EDGE-MNGT
permit ip 10.8.8.0 0.0.0.255 172.30.100.0 0.0.0.255
permit icmp 10.8.8.0 0.0.0.255 172.30.102.0 0.0.0.255
permit tcp 10.8.8.0 0.0.0.255 eq 22 172.30.102.0 0.0.0.255 established
ip access-list extended IPSEC-5J
permit ip 192.168.50.0 0.0.0.255 149.122.30.0 0.0.0.255
ip access-list extended IPSEC-5J-NEW
permit ip 192.168.50.0 0.0.0.255 host 149.122.30.31
ip access-list extended IPSEC-CMAN
permit ip 192.168.231.0 0.0.0.255 172.23.228.0 0.0.1.255
ip access-list extended IPSEC-TR
permit ip 10.223.103.0 0.0.0.255 host 149.122.26.226
permit ip 10.223.103.0 0.0.0.255 10.223.7.0 0.0.0.255
ip access-list extended NAT-IPSEC-5J
permit ip any 149.122.30.0 0.0.0.255
ip access-list extended NAT-IPSEC-5J-NEW
permit ip any host 149.122.30.31
ip access-list extended NAT-IPSEC-CMAN
permit ip 172.30.102.0 0.0.0.255 172.23.228.0 0.0.1.255
ip access-list extended NAT-IPSEC-TR
permit ip any host 149.122.26.226
permit ip any 10.223.7.0 0.0.0.255
ip access-list extended RA-VPN-HELICON-MIS
permit ip 172.30.100.0 0.0.0.255 any
permit ip 172.30.102.0 0.0.0.255 any
permit ip host 10.8.9.1 any
ip access-list extended RA-VPN-IPSEC
permit ip 192.168.211.0 0.0.0.255 149.122.0.0 0.0.255.255
ip access-list extended RA-VPN-SKYSPEED
permit ip host 149.122.26.226 any
permit ip host 149.122.30.31 any
permit ip host 120.89.33.83 any
permit ip host 172.30.100.3 any
route-map STATIC-TO-OSPF permit 10
match ip address STATIC-TO-OSPF
route-map LOCAL-POLICY-ROUTING permit 10
match ip address EDGE-MNGT
set ip next-hop 10.8.8.1
route-map RA-VPN-IPSEC permit 10
match ip address RA-VPN-IPSEC
set interface Loopback0
I'm curious about the below.  I you sure you were matching on user-fqdn before, rather than IP address?
Yes that is the matching before they changed public ip address.
Maybe something has got some bad state.  Try giving your device a reboot.
Noted on this. Will give you an update after the device boot up. Thank you very much!
I suspect it must be the remote end then.  If your end was working before, then it should be working now.  I don't see anything wrong with your config.
I guess if you are keen you can do a:
debug crypto isakmp
debug crypto ipsec
and post the output once the VPN has failed to build.
Okay. Will do. Thank you very much!
Hi Philip,
Upon adjusting on the remote site. It can now established connection. But can't access the host that needed to be accessed.
after restarting no luck.. After checking the session and crypto isakmp sa these are the results.
Profile: ISAKMP-5J
120.89.33.83 10.8.32.3 MM_NO_STATE 0 ACTIVE (deleted)
Here is the config on the other site. This was send to me by the assigned IT. I don't know which side has a problem. Is it on us, or to the other site. See attached file for your reference. Thank you very much!
Philip D'Ath
What did their IP address change from and to?
the previous IP address is 203.177.104.66 and changed to 120.89.33.83, The only changes on their side is their Public ip address.
Thank you again!
