VPN not working between Two Router
sjenkinsLNS
Another tech and myself have been trying for several days to get a VPN working between our homes and our shop. We are both fairly new to VPN(ing) on Cisco and are unsure what we are forgetting to configure. The following is my config from my home router, which mirrors the config for the shop, except with a dialer interface for my ATM DSL module (and with the appropriate IP's swapped). Any help would be greatly appreciated.
Current configuration : 2411 bytes
! Last configuration change at 21:12:34 UTC Tue Sep 16 2014 by admin
version 15.1
hostname Cisco2811
boot-start-marker
boot system flash c2800avdsecurity.bin
boot system flash c2800nm-advipservicesk9-mz.151-3.T4.bin
boot-end-marker
enable password 404-NoPasswordFound
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
vpdn enable
voice-card 0
license udi pid CISCO2811 sn BL4NK
username admin privilege 15 secret 5 404-NoPasswordFound
redundancy
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key secret-key address [PeerExternal-IP]
crypto ipsec transform-set VPNSet esp-3des esp-md5-hmac
crypto map CryptoMap 1 ipsec-isakmp
 set peer [PeerExternal-IP]
 set transform-set VPNSet
 match address 101
bba-group pppoe global
interface FastEthernet0/0
 ip address 10.40.0.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface ATM0/1/0
 mtu 1492
 no ip address
 ip tcp adjust-mss 1452
 no atm ilmi-keepalive
 hold-queue 224 in
interface ATM0/1/0.1 point-to-point
 pvc 0/35
  pppoe-client dial-pool-number 1
interface Serial0/2/0
 no ip address
 shutdown
 clock rate 2000000
interface Dialer0
 mtu 1492
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp authentication pap callin
 ppp pap sent-username username@isp.net password 0 404-NoPasswordFound
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
logging esm config
access-list 1 permit 10.40.0.0 0.0.0.255
access-list 101 permit ip 10.40.0.0 0.0.0.255 10.14.0.0 0.0.255.255
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0
 login local
 transport input telnet ssh
line vty 1 4
 login local
line vty 5
 login
scheduler allocate 20000 1000
end
hello,
I just see the configuration, and I noticed that you are missing a NAT 0 statement on the router.
To accomplish on sending traffic across and receive it from this router perspective you will need to do the following:
access-list 111 deny   ip 10.40.0.0 0.0.0.255 10.14.0.0 0.0.255.255
access-list 111 permit ip 10.40.0.0 0.0.0.255 any
route-map nonat permit 11
  match ip address 111
ip nat inside source route-map nonat interface Dialer0 overload
With these you are avoiding the router to translate the inside hosts when going to --> 10.14.0.0  /16.
Also make sure the other side of the tunnel meet with these, so you won't run into conflicts.
Let me know how it works out.
Please don't forget to rate.
Best Regards,
David Castro,
John Blakley
Much like what David said, you shouldn't nat over the tunnel. On both ends, you'll want to deny natting but it can also be done without a route-map:
ip nat inside source list 111 interface dialer0 overload
The other side would have:
access-list 111 deny   ip 10.14.0.0 0.0.0.255 10.40.0.0 0.0.255.255
access-list 111 permit ip 10.14.0.0 0.0.0.255 any
HTH,
John
HTH, John *** Please rate all useful posts ***
It looks you forgot to define crypto map local-address, I think the solution is:
(config)#crypto map CryptoMap 1 local-address Dialer0
Houtan
