VPN not working from one site
dirkmelvin
Can someone explain to me these errors?
This is from 2 separate connection attempts, from one PC. It will not connect to my PIX, but I have 2 other PCs at different locations that can connect with no problem.
What I am assuming is there is a firewall or router blocking something about VPN from the inside to the outside world?
Richard Burts
Dirk
The logs that you posted show that the intial phase 1 negotiation of ISAKMP are successful and the phase 1 SA is established as shown in these messages:
74 14:02:40.986 08/22/08 Sev=Info/4 CM/0x6310000E
Established Phase 1 SA. 1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
75 14:02:40.986 08/22/08 Sev=Info/4 CM/0x6310000E
Established Phase 1 SA. 1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
The next thing is this:
Client sending a firewall request to concentrator
and it seems that then the negotiations do not progress and there is a series of retransmissions and eventual failure.
I wonder if the other PCs that are working are set up the same way that this one is, especially relative to any firewall?
I also noticed these messages in the logs:
Remote end is NOT behind a NAT device
This end IS behind a NAT device
and I wonder if the other PCs that work are also begind a NAT device?
Rick
Rick
thiru.vel10
Thank you both so much for the feedback, I will look into this over the next day or two and post my findings.
