04-18-2006 11:29 PM - edited 03-03-2019 12:26 PM
how do i log the vpn logs in cisco 1751 routers, i wanted the logs of the person who ever is connecting the vpn router etc....
i configured easy vpn router on 1751
04-18-2006 11:54 PM
It depends on how you set it up if your using radius for a second level of authentication you can look at your radius server. If you using local authentication you might be able to setup snmp traps to show when someone is authenticated.
Patrick
Please rate any posts that are helpful.
04-19-2006 12:37 AM
i am planning to setup with a local authencation using snmp traps, so tell me how do i proceed?
