VPN second peer
acbenny
If I want to set second peer in the ipsec-isakmp, anyone know what is the minimum IOS version
crypto map abc 1 ipsec-isakmp
set peer 10.1.1.1
set peer 10.2.2.2
Richard Burts
Jack
I am pretty sure that I have been putting 2 set peers into an instance of a crypto map since at least 12.3 and I suspect that it goes further back than that. Is there a particular version that you are interested in? It may be easier to figure out support in a particular version than it is to track how far back the feature is supported?
Rick
Rick
Yes, Rick, I do not know specifically, but I have done this with 12.x code. If there is a concern, download the latest IOS.
