VPN site to site Cisco 887VA
santiagocuesta
Hi everyone, i have an question about the Cisco 887VA.
I have a router cisco 887VA working perfectly.
I already have a site to site VPN working with pre shared key and when i try to add another site to site VPN but to authenticate with certificate i have an error that said:
"Existing VPN tunnel will be reset to add this vpn configuration. Do you want to proceed?"
I dont know if i can have 2 VPN site to site but with different authentications one with passphrase and other with certificate.
I don`t want to erase my previous configuration of the vpn
Thanks for you help
5 Replies 5
the 880 supports 20 IPSec tunnels.
Can you post the config and indicate what command is generating the warning ?
Hello, thanks for your answer. I read on the internet that this router have the hability of manage 20 VPN IPsec tunnels but when i tried to add my new vpn i have recibed the error before mentioned.
Well, I try to add the new vpn connection with the wizard that i have on Cisco Configuration Professional 2.8.
Should I create the new VPN on the command line ??
Thanks for your help.
yes, configuring another tunnel via the command line, give that a try. The command line gives you many more options.
Ok, i do that so. I search on the community how to create it via the command line. My main fear is that the VPN that I have configured stops working. I tried to did it with the CCP because it has GUI and looks more friendly.
check the link below:
http://www.dslreports.com/forum/r27515828-VPN-between-two-Cisco-887VA-devices
