Strange things happen...what worked earlier, doesn't work anymore.
When i have the vpn tunnel up (192.168.253.24), i can't ping the lan on the other side (for instance 192.168.1.77)
When i connect to the router using putty, i can ping 192.168.1.77 from the router.
Now i know that when i use tracert 192.168.1.77, the first hop is the public ip address from the other router. So i can assume that my tunnel is working. But all other hops are a request timed out.
My laptop (connected to router A) gets ip 192.168.253.24 from router B as soon i have the tunnel enabled between router A and B.
Config is as follows:
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp policy 2
encr aes
group 2
crypto isakmp key AAA address 178.85.x.x
crypto isakmp client configuration group vpnclient
key AAA
dns 8.8.8.8
domain home.local
pool ipvpnpool
acl 105
crypto ipsec transform-set MySet esp-3des esp-sha-hmac
mode tunnel
crypto dynamic-map dynmap 10
set transform-set MySet
reverse-route
crypto map MyMap client authentication list userauthen
crypto map MyMap isakmp authorization list groupauthor
crypto map MyMap client configuration address respond
crypto map MyMap 1 ipsec-isakmp
set peer X.X.X.X
set security-association lifetime seconds 86400
match address 101
crypto map MyMap 20 ipsec-isakmp dynamic dynmap
crypto map MyMap
ip local pool ipvpnpool 192.168.253.10 192.168.253.30
ip nat inside source list 102 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
no cdp run
route-map nonat permit 10
match ip address 103
access-list 101 remark Cryptomap-IPSEC-VPN-BM
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.253.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.50.0 0.0.0.255 any
access-list 102 deny ip 192.168.1.0 0.0.0.255 192.168.253.0 0.0.0.255
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 192.168.50.0 0.0.0.255 any
access-list 102 deny ip 192.168.50.0 0.0.0.255 192.168.253.0 0.0.0.255
access-list 102 permit ip 192.168.51.0 0.0.0.255 any
access-list 103 remark nat rules
access-list 103 deny ip 192.168.1.0 0.0.0.255 192.168.253.0 0.0.0.255
access-list 103 permit ip 192.168.1.0 0.0.0.255 any
access-list 103 permit ip 192.168.50.0 0.0.0.255 any
access-list 103 permit ip 192.168.51.0 0.0.0.255 any
access-list 105 permit ip 192.168.1.0 0.0.0.255 192.168.253.0 0.0.0.255
Can anyone shed some light on to this?
Any help much appreciated !!
