11-09-2021 07:13 AM
Hello all,
I'm struggling to access some web servers from client VPN. I suspect that there is asymmetric routing since VPN device and web servers are in the same VLAN on the switch and in the same security zone on the firewall. Please see the below diagram.
Gateway, VPN device, and web servers are in 10.10.10/24 subnet
VPN tunnel is on 10.112.124.0/24 and on the firewall there is a static route to VPN tunnel(10.112.124.0/24) via VPN device (10.10.10.18)
Do you think the return traffic is going via L2 on the switch? I'm really confused.
Thanks.
Cheer,
Isac
11-09-2021 08:48 AM
--> I'm struggling to access some web servers from client VPN.
Can you access the web servers at all ? Which IP addresses are your VPN clients getting ?
Post the configuration of the Cisco switch...
11-09-2021 09:23 AM
Hello Georg,
Web servers can be accessed from anywhere else except the client VPN.
VPN clients gets IP from this range 10.112.124.0/24.
Isac
