VPN tunnel issue
takhellnadmin
I'm facing an issue with VPN tunnel.
Side 1: checkpoint
Phase 2:
   phase2ikealgs aes128/sha1
   phase2exptime 28800
   phase2dhgroup group2
Phase 1:
   phase1ikealgs aes128/md5
   phase1exptime 1440
   phase1dhgroup group2
Side 2: Cisco
crypto map extranet-vpn 250 ipsec-isakmp
set peer x.x.x.x.
set security-association lifetime seconds 28800
set transform-set extranet-vpn-aes128
set pfs group2
set peer x.x.x.x.x
set pfs group2
match address vpn-cccc-Prod
Access list is also right.
Log error
7556837: May 31 03:48:27.019: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 210.87.31.253
7556838: May 31 03:50:27.846: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 210.87.31.253
7556839: May 31 03:51:57.431: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 210.87.31.253
7556840: May 31 03:53:57.274: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 210.87.31.253
7556841: May 31 03:55:27.648: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 210.87.31.253
7556842: May 31 03:57:27.163: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 210.87.31.253
7556843: May 31 03:58:57.860: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 210.87.31.253
7556844: May 31 04:00:57.291: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 210.87.31.253
Debug is attached. I have tried with multiple people with no outcome. Hoping o get some answer here.
Nirvan
ashok_boin
Level 5
Level 5
Hi Nirvan,
You have incompatible policy issue. Please check transform set.
This link may help you out..
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a00801d55aa.shtml
Regards...
-Ashok.
With best regards...
Ashok
transform set is as below; It is correct considering the debug output.
crypto ipsec transform-set extranet-vpn-aes128 esp-aes esp-sha-hmac
May 31 03:41:57.664: ISAKMP: transform 1, ESP_AES
7556553: May 31 03:41:57.664: ISAKMP:   attributes in transform:
7556554: May 31 03:41:57.664: ISAKMP:      SA life type in seconds
7556555: May 31 03:41:57.664: ISAKMP:      SA life duration (VPI) of  0x0 0x0 0x70 0x80
7556556: May 31 03:41:57.664: ISAKMP:      group is 2
7556557: May 31 03:41:57.664: ISAKMP:      encaps is 1 (Tunnel)
7556558: May 31 03:41:57.664: ISAKMP:      authenticator is HMAC-SHA
7556559: May 31 03:41:57.664: ISAKMP:      key length is 128
7556560: May 31 03:41:57.664: ISAKMP (0:703): atts are acceptable.
7556561: May 31 03:41:57.664: ISAKMP (0:703): IPSec policy invalidated proposal
7556562: May 31 03:41:57.664: ISAKMP (0:703): phase 2 SA policy not acceptable! (local 202.2.57.190 remote 210.87.31.253)
7556563: May 31 03:41:57.664: ISAKMP: set new node 1100023420 to QM_IDLE
7556564: May 31 03:41:57.664: ISAKMP (0:703): sending packet to 210.87.31.253 my_port 500 peer_port 500 (R) QM_IDLE
7556565: May 31 03:41:57.664: ISAKMP (0:703): purging node 1100023420
7556566: May 31 03:41:57.664: ISAKMP (0:703): deleting node 543734380 error TRUE reason "quick mode rejected"
7556567: May 31 03:41:57.664: ISAKMP (0:703): Unknown Input for node 543734380: state = IKE_QM_READY, major = 0x00000001, minor = 0x0000000C May 31 03:41:57.664: ISAKMP: transform 1, ESP_AES
Hi Nirvan,
What state you are able to see with your remote peer?
Please past the "sh cry isa sa" output here.
As per the log it seems there was no ISAKMP policy match between the two endpoints.
Please check the pre-shared key which should be same at both end points.
If the preshared secrets are not the sameon both sides, the negotiation will fail
Please rate the helpfull posts.
Naidu.
