VPN tunnels using peer FQDN rather than ip address
mali
Hello
Any sample configuration to terminate site to site ,easy vpn tunnels using FQDN like vpn.cisco.com rather than ip address ?
kwillacey
Level 3
Level 3
It's the same as the normal configuration except that you use the FQDN with the set peer command under the crypto map and ensure that you configure a dns server on the router that can resolve the FQDN to an IP address.
I've never tried this before I just assume that's how it would work.
somebody just told me that Cisco does not suport site to site tunnels with FQDN...surprised
