VPS Wirguard CGNAT
erverg
Hello
I have a homeserver which is behind a CGNAT. Therefore, I use a VPS with public IP which is connected to my virtual opnsense via WireGuard to avoid this. This works perfectly, and I can route the traffic from the VPS directly to my VMs. But I have a major problem because I only see the WireGuard IP of the VPS (192.168.4.1) on the VMs and not the IPs of the source IPs of the clients that come in via the VPS. So every Client who is connected has the same IP. I have been trying for days to find a solution, but I am desperate. I have also tried to establish the WireGuard connection to another server directly, but also I see only the IP of the VPS Wireguard. What i make wrong here?
wg0.conf:
PostUp = iptables -A FORWARD -i eth0 -o wg0 -j ACCEPT
PostUp = iptables -A FORWARD -i wg0 -o eth0 -j ACCEPT
#HTTP/HTTPS
PostUp = iptables -t nat -A PREROUTING -i eth0 -p tcp -m multiport --dport 80 -j DNAT --to 10.0.102.2
PostUp = iptables -t nat -A PREROUTING -i eth0 -p tcp -m multiport --dport 443 -j DNAT --to 10.0.102.2
#XMPP
PostUp = iptables -t nat -A PREROUTING -i eth0 -p tcp -m multiport --dport 5000 -j DNAT --to 10.0.101.2
PostUp = iptables -t nat -A PREROUTING -i eth0 -p tcp -m multiport --dport 5222 -j DNAT --to 10.0.101.2
PostUp = iptables -t nat -A PREROUTING -i eth0 -p tcp -m multiport --dport 5223 -j DNAT --to 10.0.101.2
PostUp = iptables -t nat -A PREROUTING -i eth0 -p tcp -m multiport --dport 5269 -j DNAT --to 10.0.101.2
PostUp = iptables -t nat -A PREROUTING -i eth0 -p tcp -m multiport --dport 5280 -j DNAT --to 10.0.101.2
PostUp = iptables -t nat -A PREROUTING -i eth0 -p tcp -m multiport --dport 5281 -j DNAT --to 10.0.101.2
PostUp = iptables -t nat -A POSTROUTING -o wg0 -j MASQUERADE
PostDown = iptables -D FORWARD -i eth0 -o wg0 -j ACCEPT
PostDown = iptables -D FORWARD -i wg0 -o eth0 -j ACCEPT
#HTTP/HTTPS
PostDown = iptables -t nat -D PREROUTING -i eth0 -p tcp -m multiport --dport 80 -j DNAT --to 10.0.102.2
PostDown = iptables -t nat -D PREROUTING -i eth0 -p tcp -m multiport --dport 443 -j DNAT --to 10.0.102.2
#XMPP
PostDown = iptables -t nat -D PREROUTING -i eth0 -p tcp -m multiport --dport 5000 -j DNAT --to 10.0.101.2
PostDown = iptables -t nat -D PREROUTING -i eth0 -p tcp -m multiport --dport 5222 -j DNAT --to 10.0.101.2
PostDown = iptables -t nat -D PREROUTING -i eth0 -p tcp -m multiport --dport 5223 -j DNAT --to 10.0.101.2
PostDown = iptables -t nat -D PREROUTING -i eth0 -p tcp -m multiport --dport 5269 -j DNAT --to 10.0.101.2
PostDown = iptables -t nat -D PREROUTING -i eth0 -p tcp -m multiport --dport 5280 -j DNAT --to 10.0.101.2
PostDown = iptables -t nat -D PREROUTING -i eth0 -p tcp -m multiport --dport 5281 -j DNAT --to 10.0.101.2
PostDown = iptables -t nat -D POSTROUTING -o wg0 -j MASQUERADE
Network:
Hello
TBH not familiar with your setup here, can you elaborate how the VPS and your internal vms connect.
If I’m not mistaken it looks like you are still behind cgnat box via you home router with the VPS reachable via your ISPs cgnat pip?
If so, then you still won’t have an accessible public ip address as your home router will have the cnat address. -  Maybe UPnP could assist but I wouldnt recommend it.
Kind Regards
Paul
Chloeharper
Ah, dealing with WireGuard on a VPS behind CGNAT can be tricky. Since CGNAT hides your public IP, you might run into issues with direct connections or port forwarding. Some VPS providers like arzhost offer setups or guides to handle VPNs properly even with CGNAT which can save a lot of headache.
Are you trying to connect multiple clients through WireGuard, or just set up a personal VPN?
Chloe Harper | ARZ Host Team
Helping users with reliable and scalable hosting solutions — arzhost.com
Support: support@arzhost.com
