VRF DHCP help!
frederick.mercado
So I have my VRF lite setup in the WLC 9800 oddly enough that includes VLAN(Mobile clients) and Interface twoGi0/0/0 out to the ISP. I cannot however get DHCP. The DHCP server is behind VLAN  on the corp network, as we have to have it windows based due to policy, if not I would surely set one up locally. The only issue is that we do not have a SVI on the corp for VLAN...I know the route leak from VRF to global but VLAN is not in the global...but I am unsure of how to set that up... as I do not want communication with anything but DHCP to that VRF.
6 Replies 6
Edit you post please and delete sensitivy information.
Try this config:
ip vrf MOBILE-SSID
description MOBILE to ISP
rd 1:1
access-list 101 permit ip 207.91.252.28 0.0.0.255 10.74.35.10 0.0.0.255
route-map VRF_TO_GLOBAL permit 10
match ip address 101
set global
interface TwoGigabitEthernet0/0/0
description LOCAL INTERNET
no switchport
ip vrf forwarding MOBILE-SSID
ip address 207.91.252.28 255.255.255.248
ip helper-address 10.74.35.10
ip nat outside
negotiation auto
no snmp trap link-status
ip policy route-map VRF_TO_GLOBAL
Configured but not working.
But the VLAN 126 and 35  are  an interface vlan?  Or they are only layer 2 vlans?
If they are interface vlan then, is different from what I thought
The  policy must be applied on the interface vlan that has the VRF on it
The access list must use the source IP of the interfac vlan with VRF and destination the VLAN on the global vrf
They are layer 2 vlans on the 9800 WLC.
Hello
You have a post open already (here) relating to the same query ( vrf, vlan 126,dhcp) in this that post it was summarized to
@paul.driver wrote
So just to summarise, you have a HSRP vlan that you want isolated from the rest of the network, be able to receive dhcp allocation and append NAT redundancy to froma 9300 series switch?
@frederick.mercado wrote:
That would be a correct summarization. VLAN126 is for mobile traffic to be isolated from other VLANs, minus the possible DHCP,
Kind Regards
Paul
