Showing results forĀ
Search instead forĀ
Did you mean:Ā
VRF forward / receive, which one is best?
gordonderick
Can anyone tell me  the difference between 'ip vrf receive' and 'ip vrf forwarding', do these 2 commands put the interfaces in the VRF?
I have a interface on the core configured with 'ip vrf recieve' (config below). Wheneve the edge device is disconnected from the network the 'ip vrf receive' command disappears from the running config.
emnewol#sh run int f1/1.101
Building configuration...
Current configuration : 223 bytes
interface FastEthernet1/1.101
description CKTI149
bandwidth 10000
encapsulation dot1Q 101
ip vrf receive curriculum
ip address 10.54.68.21 255.255.255.252
ip policy route-map Native
end
Harold Ritter
Hi Gordon,
"ip vrf receive" is used in the context of multi-vrf selection, which allows to have multiple VRF assigned to an interface and to select one the other basec on the source address (or other information using PBR).
"ip vrf forwarding" enables one VRF on a given interface.
Multi-VRF Selection Using Policy Based Routing (PBR)
www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_mltvrf_slct_pbr.html
Hope this helps
Thanks for replying. That makes sense.
