06-17-2012 05:10 AM - edited 03-04-2019 04:42 PM
We have a problem to in install Internat via VRF . I have a problen in the nat and real ip address will be put as loopback or secondary address.We tried the both .THe real ip address is pingable from the internet .The proble our lan can not go outside the internet but go the branches.Kinldy find my following config
interface GigabitEthernet0/1
description Main-Conn
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.650
description VPN
encapsulation dot1Q 650
ip address 172.17.24.252 255.255.255.248
interface GigabitEthernet0/1.750
description Internet
encapsulation dot1Q 750
ip vrf forwarding internet
ip address 172.17.25.214 255.255.255.252
interface GigabitEthernet0/0
description LAN
ip address 192.168.201.0 255.255.255.0
duplex auto
speed auto
ip route 192.168.100.0 255.255.255.0 172.17.24.249
ip route 192.168.101.0 255.255.255.0 172.17.24.249
ip route 192.168.102.0 255.255.255.0 172.17.24.249
ip route 192.168.103.0 255.255.255.0 172.17.24.249
ip route 192.168.122.0 255.255.255.0 172.17.24.249
ip route 192.168.202.0 255.255.255.0 172.17.24.249
ip route 192.168.217.0 255.255.255.0 172.17.24.249
ip route 192.168.222.0 255.255.255.0 172.17.24.249
ip route 192.168.230.0 255.255.255.0 172.17.24.249
ip route 192.168.224.0 255.255.255.0 172.17.24.249
ip route 192.168.124.0 255.255.255.0 172.17.24.249
interface Loopback0
ip address 40.30.167.90 255.255.255.224
int Gi0/1.750
ip nat enable
int Gi0/0
ip nat enable
accessl-list 101 deny 192.168.201.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 101 permit 192.168.201.0 0.0.0.255 any
ip nat pool REAL 40.30.167.90 40.30.167.90 prefix-length 27
ip source nat inside list 101 pool REAL vrf internet overload
ip route vrf internet 0.0.0.0 0.0.0.0 172.17.25.213
06-17-2012 05:40 AM
Mohamed,
On your router, you'll need to create routes that allow the Internet vrf back into the global routing table. For example, try putting in:
ip route vrf Internet 192.168.230.0 255.255.255.0
A host in subnet 192.168.230.0 should be able to get to the internet. The problem is that you've created a separate routing table for your Internet connection, but it looks like all of your hosts are not in vrfs which are still a part of the global routing table.
HTH,
John
06-17-2012 06:30 AM
description LAN
duplex auto
speed auto
Did you put 192.168.201.0 255.255.255.0 as you interfaces IP address on purpose?
im not sure, but shouldnt u create ur VRF internet (ip vrf internet) globaly too? plus a route back to ur LAN as John said.
plz Rate if it helped.
Soroush.
