VRF leaking - basic setup
Cedric T.
Frequent Visitor
Frequent Visitor
As an attempt to solve a broader problem, I decided to divide it in smaller parts.
One of which is the following: how to setup a basic inter-vrf communications path with statics routes from each VRF to the global routing table and then from the global routing table to the other VRF.
Let say we have a router with:
- port 3 in vlan 3 with IP 192.168.3.1/24 in vrf3
- port 4 in vlan 4 with IP 192.168..4.1/24 in vrf4
We want to allow communications from network 192.168.3.0 to network 192.168.4.0 and vice-versa.
Here is a sample of the configuration:
interface FastEthernet0/0/3
switchport mode access
switchport access vlan 3
interface FastEthernet0/0/4
switchport access vlan 4
exit
vrf definition vrf3
address-family ipv4
exit-address-family
vrf definition vrf4
address-family ipv4
exit-address-family
interface vlan3
vrf forwarding vrf3
ip address 192.168.3.1 255.255.255.0
exit
interface vlan4
vrf forwarding vrf4
ip address 192.168.4.1 255.255.255.0
exit
! static routes in each vrf
ip route vrf vrf3 192.168.4.0 255.255.255.0 192.168.4.1 global
ip route vrf vrf4 192.168.3.0 255.255.255.0 192.168.3.1 global
! routes in the global table
ip route 192.168.3.1 255.255.255.255 vlan3
ip route 192.168.4.1 255.255.255.255 vlan4
I must be missing something because it does not work.
I know you would say it make no sense to use VRF in this case but, I recall, this is a simplified part of a broader problem.
Thanks for your ideas,
Cedric T.
Hello
Why not put them in the same VRF and route-leak to whatever other rib table you wish?
Kind Regards
Paul
Because in the broader problem, there are 2 different VRFs and I cannot change that.
Note that in my original post, I stated: "I know you would say it make no sense to use VRF in this case but, I recall, this is a simplified part of a broader problem".
Best regards,
Cedric T.
Hello
I would say it would work if you specified a next hop address in the vrf x statics but it dont looklike you can due to them being logical SVI's
ip route vrf vrf3 192.168.4.0 255.255.255.0 vlan3 192.168.4.x global
ip route vrf vrf4  192.168.3.0 255.255.255.0 vlan4 192.168.3.x global
Kind Regards
Paul
Hi Cedric,
If it is okay to run BGP, you can leak routes between the two VRFs.
Here is a sample config:-
exit
vrf definition vrf3
rd 3:3
address-family ipv4
 route-target both 3:3
 route-target import 4:4
exit-address-family
vrf definition vrf4
 rd 4:4
address-family ipv4
 route-target both 4:4
 route-target import 3:3
exit-address-family
interface vlan3
vrf forwarding vrf3
exit
interface vlan4
vrf forwarding vrf4
exit
router bgp 65001
 address-family ipv4 vrf vrf3
  redistribute connected
 address-family ipv4 vrf vrf4
HTH,
Meheretab
