VRF + OSPF configuration help
merryllem
Hello All,
I'm issues configuring the OSPF for a specific VRF instance. I get the following error (using 3700 12.4(15)T11)
VRFRTR(config)#ROUTER OSPF 100 VRf STUB
%VRF specified does not match this router
However when I configure the address family in EIGRP, ti works.
VRFRTR(config)#router eigrp 12
VRFRTR(config-router)#address-family ipv4 vrf STUB
VRFRTR(config-router-af)#exit
Here is the output of show ip VRF:
VRFRTR#show ip vrf
Name Default RD Interfaces
NSSA 30:30 Se2/2
Se1/2
STUB 10:10 Se2/0
Se1/0
TSNSSA 40:40 Se2/3
Se1/3
TSTUB 20:20 Se2/1
Se1/1
VRFRTR#
Any Ideas what im missing? .. I've attached my router configuration.
(btw this is a home lab for CCIE W test. Trying to be smart using VRF's to simulate 8 routers using only 3 routers.)
Reza Sharifi
Merrylle,
Can you post "sh ver" here?
Reza
I figured out the problem. I was copy and pasting the VRF lines. Not sure why when i typed it in it worked.
- I did verify copy and paste does not work.
