VRF Question
benolyndav
Level 4
Level 4
Our service provider has configured 3 vrf's on their interface connecting to our network,  we have a L3 peering with them and all fine with this, but these new vrf's are L2 not part of any routing so how can I put a Firewall in the path somewhere inside our Lan to control access to a Server we will be adding to new vrf, its confusing because the gateway for the vrf ,s are obviously on the provider Router.???
5 Replies 5
balaji.bandi
Summarise you have 3 VRF Layer 3 and 2 VRF Layer 2
how are they terminating to you, do you have any small diagram to undertand how exiting one connected and how the new one connected ?
BB
Attached as requested.
thanks
which firewall do you have (or plan on having) ? Most firewalls let you filter on layer 2 attributes such as MAC address as well...
I have attached a little diagram, my problem is users will come in to the network from the provider Router having treversed the vrf from remote sites the new server will have an IP Address in the vrf range on site which is mapped to vrf with vlan, so how do i controll access once requests are inside as its all L2.??
thanks
benolyndav
Level 4
Level 4
Hi Little diagram if it helps
