VRF Route Leaking Not working as expected
mediaos718
I am running 2 VRF's between a CE and PE
*VRF's name: DATA and SECURITY
*In the PE - I do route leaking (Importing the routes in each VRF).
*In the CE, I expected the DATA routes in the SECURITY table and I expected the SECURITY routed in the DATA table
*I do not have any route maps.
*In the PE, I see the advertised touter to the neighbors (or to the CE).
*In the CE, i do not see the received-routes.
See attached for the show commands.
Please help.
18 Replies 18
No attachment, re attach again
it is difficult to see what you are missing without seeing the full configs. Do you have 'address-family ipv4' configured under the vrf definitions?
ip vrf DATA
rd 20:20
route-target export 20:20
route-target import 20:20
route-target import 10:10
--> address-family ipv4
ip vrf PHONE
rd 30:30
route-target export 30:30
route-target import 30:30
ip vrf SECURITY
rd 10:10
route-target export 10:10
I attached the configs (PE and CE)
Hello
You dont seem to be sending/receiving any extended communities
Can you post:
sh  vrf detail
sh bgp vpnv4 unicast vrf DATA
sh bgp vpnv4 unicast vrf SECURITY
PE rtrs
router bgp
address-family vpnv4
neighbor x.x.x.x send-community both
Kind Regards
Paul
send-community by default,
but can I ask why both not just extended ?
are you face any error/log message
bgp couldn't find router-id in CE or PE?
Hello @MHM Cisco World
FYI send-community both enables both standard and extended
Kind Regards
Paul
Yes I know but I ask why we need here standard ?
Unless the OP post the details of the PE vrf we wont know what they are sending, but if the extended community's are not set set then that's a good possibility why the routes are not get advertised.
Kind Regards
Paul
CE-PE
there is one link or multi link ? i.e. one link for each vrf ?
CE-PE vrf data
config the link connect with
ip vrf forwarding data
CE-PE vrf voice
ip vrf forwarding voice
PE
router bgp x
address-family ipv4 vrf data
neighbor CE remote Y
address-family ipv4 vrf voice
CE
router bgp Y
neighbor
neighbor
NOW I think the issue here is using only one link?
Hello
After you've posted the running configs, you don't seem to be showing any configuration  for any AF vpns regards an mpls superbackbone (pe-p-pe) rtrs
Can you confirm how youve set this topology is up, post a diagram
Kind Regards
Paul
Paul, I realize I did not include all the info (I thought the snipet that I provided would be enough). I attached a new diagram which explains what I am trying to do.
  • I am running cisco DNA in the main site.
  • R1, R2, R3, and R3 will be the transit.
  • Now, I have to bring the remote sites into DNAC.
  • As per the diagram, R7 will be the DNA border for SITE-1 – As a result, DNAC will create multiple VRF’s in R7.
  • I will create a EBGP peering between R7 and R3 for each VN or VRF.
The issue that I am trying to solve:
If the transit (iBGP peering) is down, I would need to use the backup link to get to the main site.
The backup link will be connected in VRF DATA. (R3 and R7 are in the same Data Center) I would like to do a route leak in the DATA and SECURITY VRF’s in R3 so that the SECURITY VRF is able to use the backup link.
  • I did the route leak in R3 but I do not see the DATA VRF routes in the SECURITY VRF in R7.
  • I do see the DATA VRF routes in the SERUTITY VRF table in R7. And I can see that the routes are been advertised to R7 VRF neighbor.
this backup link is direct connect ?
