VRF traceroute/ping problem
cwalek
Frequent Visitor
Frequent Visitor
Hello guys,
I have encountered and issue when I try to traceroute/ping from one router to another. They are both in VRFs but I have configured VRF Leaking between the routers. When I try to ping/traceroute from one of the routers trough ( for example "VRF 1") it goes trough but when I try the same from ( for example "VRF 2") it doesn't go trough, altough the routers both have the routes to the destination int their BGP and Routing tables. In the topology I have suspended R4-R7 link and R1 also so in that case route has to go from R5 trough R2-R4-R11-R3-R7. R5 is in VRF "LP", when I try traceroute from R2/R4 to R7 trough VRF-DM it goes but it doesn't trough VRF-LP it stops at R11. What should I do?
R2 Config: ( Don't mind the descriptions on the interfaces they are leftover from other stage of the topology)
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip vrf CUST-DM
rd 6501:2
route-target export 6501:2
route-target import 6501:2
route-target import 6501:1
ip vrf CUST-LP
rd 6501:1
route-target export 6501:1
ip tcp synwait-time 5
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Ethernet1/0
no ip address
duplex half
interface Ethernet1/0.10
encapsulation dot1Q 10
ip vrf forwarding CUST-DM
ip address 10.2.2.1 255.255.255.252
interface Ethernet1/0.20
encapsulation dot1Q 20
ip vrf forwarding CUST-LP
interface Ethernet1/1
description ### To SW-1 ###
ip address 10.10.8.1 255.255.255.252
duplex full
interface Ethernet1/2
no ip address
shutdown
duplex half
interface Ethernet1/3
no ip address
shutdown
duplex half
interface Ethernet1/4
no ip address
shutdown
duplex half
interface Ethernet1/5
no ip address
shutdown
duplex half
interface Ethernet1/6
no ip address
shutdown
duplex half
interface Ethernet1/7
no ip address
shutdown
duplex half
interface Ethernet2/0
no ip address
shutdown
duplex half
interface Ethernet2/1
ip address 10.10.6.1 255.255.255.252
duplex half
interface Ethernet2/2
no ip address
shutdown
duplex half
interface Ethernet2/3
no ip address
shutdown
duplex half
interface FastEthernet3/0
no ip address
shutdown
duplex half
interface FastEthernet4/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet4/1
no ip address
shutdown
duplex auto
speed auto
router bgp 6500
no synchronization
bgp log-neighbor-changes
redistribute connected
no auto-summary
address-family ipv4 vrf CUST-LP
neighbor 10.2.2.2 remote-as 6500
neighbor 10.2.2.2 timers 5 20
neighbor 10.2.2.2 activate
neighbor 10.2.2.2 next-hop-self
neighbor 10.2.2.2 advertisement-interval 2
neighbor 10.10.8.2 remote-as 500
neighbor 10.10.8.2 timers 5 20
neighbor 10.10.8.2 activate
neighbor 10.10.8.2 as-override
neighbor 10.10.8.2 advertisement-interval 2
neighbor 10.10.8.2 route-map MED_PREF out
no synchronization
exit-address-family
address-family ipv4 vrf CUST-DM
redistribute connected route-map COMMUNITY_2
neighbor 10.2.2.2 send-community both
neighbor 10.10.6.2 remote-as 500
neighbor 10.10.6.2 timers 5 20
neighbor 10.10.6.2 activate
neighbor 10.10.6.2 send-community both
neighbor 10.10.6.2 as-override
neighbor 10.10.6.2 advertisement-interval 2
neighbor 10.10.6.2 route-map COMMUNITY_2 out
no synchronization
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip bgp-community new-format
no cdp log mismatch duplex
route-map MED_PREF permit 10
set metric 100
route-map COMMUNITY_2 permit 10
set community 6500:600
R4 Config:
ip cef
no ip domain lookup
ip vrf CUST-DM
rd 6503:2
route-target export 6503:2
route-target import 6503:2
route-target import 6503:1
ip vrf CUST-LP
rd 6503:1
route-target export 6503:1
interface Loopback0
ip address 4.4.4.4 255.255.255.255
no ip address
shutdown
duplex half
description ### To R2 ###
ip address 10.2.2.2 255.255.255.252
duplex half
duplex half
interface Ethernet1/1.10
shutdown
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 6500
no synchronization
no auto-summary
neighbor 10.2.2.1 remote-as 6500
neighbor 10.2.2.1 timers 5 20
neighbor 10.2.2.1 activate
neighbor 10.2.2.1 next-hop-self
neighbor 10.2.2.1 advertisement-interval 2
no synchronization
exit-address-family
neighbor 10.10.6.2 next-hop-self
neighbor 10.10.6.2 allowas-in
no synchronization
exit-address-family
no ip http server
set metric 100
R11 Config:
hostname R11
boot-start-marker
boot-end-marker
no aaa new-model
no ip cef
no ip domain lookup
interface Loopback0
ip address 11.11.11.11 255.255.255.255
ip address 172.32.0.1 255.255.255.252
duplex half
ip address 10.10.9.2 255.255.255.252
duplex half
ip address 10.10.6.2 255.255.255.252
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 500
neighbor 10.10.6.1 remote-as 6500
neighbor 10.10.6.1 timers 5 20
neighbor 10.10.9.1 remote-as 6500
neighbor 10.10.9.1 timers 5 20
neighbor 172.32.0.2 remote-as 500
neighbor 172.32.0.2 timers 5 20
address-family ipv4
neighbor 10.10.6.1 activate
neighbor 10.10.6.1 advertisement-interval 2
neighbor 10.10.6.1 route-map LP_C in
neighbor 10.10.9.1 activate
neighbor 10.10.9.1 advertisement-interval 2
neighbor 172.32.0.2 activate
neighbor 172.32.0.2 send-community both
neighbor 172.32.0.2 advertisement-interval 2
default-information originate
no auto-summary
no synchronization
exit-address-family
no ip http server
ip community-list 10 permit 6500:600
route-map LP_C permit 10
match community 10
set local-preference 350
route-map LP_C permit 20
set local-preference 100
route-map LOCAL_PREF permit 10
set local-preference 900
route-map LOCAL_PREF_2 permit 10
R3 Config : hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
ip vrf CUST-DM
rd 6502:2
route-target export 6502:2
route-target import 6502:2
route-target import 6502:1
ip vrf CUST-LP
rd 6502:1
route-target export 6502:1
interface Loopback0
ip address 3.3.3.3 255.255.255.255
no ip address
shutdown
duplex half
no ip address
duplex half
ip address 10.1.1.2 255.255.255.252
ip address 10.10.5.1 255.255.255.252
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
ip address 10.10.9.1 255.255.255.252
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 6500
no synchronization
no auto-summary
neighbor 10.1.1.1 remote-as 6500
neighbor 10.1.1.1 timers 5 20
neighbor 10.1.1.1 activate
neighbor 10.1.1.1 next-hop-self
neighbor 10.1.1.1 advertisement-interval 2
neighbor 10.10.5.2 remote-as 500
neighbor 10.10.5.2 timers 5 20
neighbor 10.10.5.2 activate
neighbor 10.10.5.2 send-community both
neighbor 10.10.5.2 as-override
neighbor 10.10.5.2 advertisement-interval 2
no synchronization
exit-address-family
neighbor 10.10.9.2 remote-as 500
neighbor 10.10.9.2 timers 5 20
neighbor 10.10.9.2 activate
neighbor 10.10.9.2 as-override
neighbor 10.10.9.2 advertisement-interval 2
neighbor 10.10.9.2 route-map MED_PREF out
no synchronization
exit-address-family
no ip http server
set metric 100
R7 Config:
no ip cef
no ip domain lookup
interface Loopback0
ip address 7.7.7.7 255.255.255.255
duplex half
ip address 10.10.5.2 255.255.255.252
duplex half
ip address 10.10.8.2 255.255.255.252
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex half
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 500
neighbor 10.10.5.1 remote-as 6500
neighbor 10.10.5.1 timers 5 20
neighbor 10.10.8.1 remote-as 6500
neighbor 10.10.8.1 timers 5 20
address-family ipv4
neighbor 10.10.5.1 activate
neighbor 10.10.5.1 advertisement-interval 2
neighbor 10.10.5.1 route-map LP_C in
neighbor 10.10.8.1 activate
neighbor 10.10.8.1 advertisement-interval 2
neighbor 10.10.8.1 route-map LOCAL_PREF_2 in
no auto-summary
no synchronization
exit-address-family
no ip http server
ip community-list 10 permit 6500:500
match community 10
NOTE: There might be route-maps that are present but not applied anywhere.
I send you PM
MHM
