VRF with RP
Johnson_Mo
team,
is there a way to force VRF joining multiple RPs as a VRF can join only  one RP multicast at a time?
5 Replies 5
Not only vrf but also in global you can config one RP for each multicast.
In vrf and multicast I think it hard
Try with global and config multi rp one for each multicast.
MHM
hi boss,
if I apply it globally, it works fine but as you said in vrf, is hard that's why I a trying to find out a way to do this under vrf.
Hello
mc within a vrfs would be the same as in the global route table
As long as your unicast routing is all setup you should just enable mc routing to your vrf - Apply pim to the vrf interfaces and specify the RPs either staticky or dynamically like BSR
Kind Regards
Paul
thanks for replying back!
applying pim to vrf int is not even a feature on my cat 9300.
thank you
Johnson_Mo
I got it resolved by the following:
ip pim vrf test rp-address 1.1.1.1 test1
ip pim vrf test rp-address 2.2.2.2 test2
now one VRF has joined to two different RPs
access-list test1
permit 239.1.1.1
access-list test2
permit 239.1.1.2
