VRF
Mlex1
Hi every one i make this topology i can ping from both ISP R1 and from R1 can ping every where, here my question from both PC i can ping only this ip address 172.16.0.0/24 and 172.16.1.0/24 i can't ping ISP ip add. this one my topology
config on ISP1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Ethernet0/0
description TO-R1
ip address 10.10.10.1 255.255.255.0
duplex auto
interface Ethernet0/1
duplex auto
config from ISP2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
description To-R1
ip address 11.11.11.1 255.255.255.0
duplex auto
ip address 192.168.1.2 255.255.255.0
duplex auto
config switch
switchport trunk allowed vlan 101,102
switchport mode trunk
switchport trunk allowed vlan 203,204
interface Ethernet0/2
switchport access vlan 203
switchport mode access
interface Ethernet0/3
switchport access vlan 204
interface Ethernet1/0
interface Ethernet1/1
interface Ethernet1/2
switchport access vlan 102
interface Ethernet1/3
switchport access vlan 101
config router
vrf definition ISP1
address-family ipv4
exit-address-family
vrf definition ISP2
address-family ipv4
exit-address-family
track 1 ip sla 1 reachability
delay down 30
track 2 ip sla 2 reachability
delay down 30
track 3 list boolean or
object 1
object 2
no ip address
no ip redirects
ip virtual-reassembly in drop-fragments
ip virtual-reassembly out drop-fragments
duplex auto
interface Ethernet0/0.101
description TO-ISP1
encapsulation dot1Q 101
vrf forwarding ISP1
ip address 10.10.10.2 255.255.255.0
no ip redirects
ip nat outside
interface Ethernet0/0.102
description TO-ISP2
encapsulation dot1Q 102
vrf forwarding ISP2
ip address 11.11.11.2 255.255.255.0
no ip redirects
ip nat outside
no ip address
no ip redirects
duplex auto
interface Ethernet0/1.203
description USER
encapsulation dot1Q 203
ip address 172.16.0.1 255.255.255.0
no ip redirects
ip nat inside
interface Ethernet0/1.204
description USER
encapsulation dot1Q 204
ip address 172.16.1.1 255.255.255.0
no ip redirects
ip nat inside
ip nat source route-map RM_NAT_ISP1 interface Ethernet0/0.101 overload
ip nat source route-map RM_NAT_ISP2 interface Ethernet0/0.102 overload
ip route 0.0.0.0 0.0.0.0 Ethernet0/0.101 10.10.10.1 50 name ISP1 track 1
ip route 0.0.0.0 0.0.0.0 Ethernet0/0.102 11.11.11.1 100 name ISP2 track 2
ip route vrf ISP1 0.0.0.0 0.0.0.0 10.10.10.1
ip route vrf ISP2 0.0.0.0 0.0.0.0 11.11.11.1
ip access-list extended NAT
permit ip 172.16.0.0 0.0.0.255 any
permit ip 172.16.1.0 0.0.0.255 any
ip sla 1
icmp-echo 1.1.1.1 source-interface Ethernet0/0.101
vrf ISP1
frequency 10
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 2.2.2.2 source-interface Ethernet0/0.102
vrf ISP2
frequency 10
ip sla schedule 2 life forever start-time now
ipv6 ioam timestamp
route-map RM_NAT_ISP2 permit 10
match ip address NAT
match interface Ethernet0/0.102
route-map RM_NAT_ISP1 permit 10
match interface Ethernet0/0.101
Wish all the best
Mlex1
here i made mistake after this i able ping every where i delete my ip nat outside/inside and typed ip nat enable
description TO-ISP1
vrf forwarding ISP1
no ip redirects
ip nat outside [ip nat enable]
description TO-ISP2
vrf forwarding ISP2
no ip redirects
no ip address
no ip redirects
duplex auto
description USER
no ip redirects
ip nat inside [ip nat enable]
description USER
no ip redirects
Wish all the best
14 Replies 14
you config two VRF one for each ISP, and LAN is in GRT (global routing table)
so first you need static route between GRT and VRF
second I see track and I think also you config IP SLA so you also need IP SLA to be VRF aware.
you mean i should configure static route between ISP and R1?
Wish all the best
Hello
The rtr needs to be able to route between VRF tables and the GRT of the lan subnets, try the following:
ip route vrf ISP1 172.16.0.0 255.255.255.0 eth0/1.23 global
ip route vrf ISP1 172.16.1.0 255.255.255.0 eth0/1.24 global
ip route vrf ISP2 172.16.0.0 255.255.255.0 eth0/1.23 global
ip route vrf ISP2 172.16.1.0 255.255.255.0 eth0/1.24 global
Kind Regards
Paul
i try your option, here mistake
R1(config)#ip route vrf ISP1 172.16.0.0 255.255.255.0 ethernet0/1.203
% For VPN or topology routes, must specify a next hop IP address if not a point-to-p
oint interface
R1(config)#
R1(config)#ip route vrf ISP1 172.16.1.0 255.255.255.0 ethernet 0/1.204 ?
<1-255> Distance metric for this route
A.B.C.D Forwarding router's address
DHCP Default Gateway obtained from DHCP
multicast multicast route
name Specify name of the next hop
permanent permanent route
tag Set tag for this route
track Install route depending on tracked item
<cr>
R1(config)#ip route vrf ISP1 172.16.1.0 255.255.255.0 ethernet 0/1.204 global
% Invalid input detected at '^' marker.
R1(config)#
Wish all the best
Hello
I had a feeling the rtr would complain about no nexthop so specify host as next hop it should then be accepted
Kind Regards
Paul
appropriate for your support i found solution tomorrow i will share
Wish all the best
I will check the config and send update
Router doesn't accept this command
Wish all the best
by the way i have like this route on R1
Wish all the best
appropriate for your support i found solution tomorrow i will share answer
Wish all the best
glad your issue is solved.
good luck  friend.
Mlex1
description TO-ISP1
vrf forwarding ISP1
no ip redirects
description TO-ISP2
vrf forwarding ISP2
no ip redirects
no ip address
no ip redirects
duplex auto
description USER
no ip redirects
description USER
no ip redirects
Wish all the best
Hello
what you are using is NVI nat (domainless)
This is indeed is  used for vrf nat - the nvi interface it creates is used for nat traffic as such no nat domains (inside:outside) or route leaking between vrf/grt is  required
TBH i didn’t suggest this as the assumption was you were using PT simulation which i’m on the understanding it isnt supported - anyway thanks for sharing your solution.
Kind Regards
Paul
yes i also read about it on internet
Kind Regards
Parvin
Wish all the best
