VRRP and config sync
domenic.alvaro
When using Cisco 2911 ISR with VRRP is it possible to automatically sync the configuration between two routers, or do I need to manually apply the same configuration changes to both?
Is VRRP the best option for High Availability for these routers?
Francis Garcia
Depending your implementation GLBP, VRRP or HSRP can work, VRRP is the best option if you pretend to use a non Cisco hardware for redundacy. I use it in my network between a 1760 and a c857 and I can say it is so robust, it supports authentication and tracking using SLA. If you need to load balance the traffic between multiple gateways GLBP is the best fit for you. Redundacy = VRRP and HSRP. Outgoing gateway loadbalance= GLBP. About the configuration synchronization It's better to wait for someone else, because I haven't done this yet.
